New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
hartiberlin
Hmm,
it does not seem to slow down.
so the friction would have killed it already after a few spins, if the top white shaped thing would
only work as a start acceleration by letting it go from the top..
I hope he will show it in an outdoor location where there could be no
hidden coils or something like this.
I suggested this already to the  inventor Roobert33 and I hope he will come
forward with more infos.
Regards, Stefan.
hartiberlin
Actually, you see at Minute 1:33 as he pulled the plug and the white shaped circle thing hits the
upper magnet repeller the first time, that the wheel accelerates !
So it is accelerating to a speed, where the friction and magnet-gravity propellation
balances out its forces.
I agree, that it would be nice to see it running much longer time and
in a place, where there could be no hidden power sources like hidden coils
Regards, Stefan.
Bruce_TPU
Just to give my dime's worth of observation.  The white disc thing is only used as a mechanical mechanism, used to lift (top and bottom) both magnets at just the perfect time, to prevent the "sticky spot" from stopping the motor.   It is using this mechanical aspect to overcome the much reknown sticky spot.  That is the only reason it is there, and the device would otherwise not work.  I think it is a fine piece of engineering (if real) and a creative approach.
Bruce
ramset
Stephan,
Are you in contact with the builder?
Looks along the lines of Ehrfinder's Design [which he never Open sourced].
Thank you,
Chet
Thanks Grandma
