New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Arrow
Hi guys, happy new year!!!
After examining patent presented above, we found out dependence that never noticed.
V- angle has about 5 degree angle, don't you? OK, the first  narrow part of gate - 3 magnets gap for 6x6mm magnets is 6mm, at the next stage when angular distance becoming bigger the gap between magnets also must be changed to bigger.A bit later I will tell you the right dependence of the gaps to angular distance change.Why we had focused to this point and start examination - we noticed that bar magnet not from all places on the flat V-gate has the same attraction force, even there are some place that we did not have attraction absolutely. If V-gate is serial windowed system then from all place at the gate liner distance we shall get the same at taction force, but we did not! So, we had come to the hard conclusion that gap between the magnets has to be different as much as the liner angular distance between N and S sides of gate becoming bigger. We need other portion of experiments to find that dependence formula. We are very close to see our gate perfect guys, this is very good note that we made for us! New Year very good wine help us to think relaxed:))))))))))))
BTW if you have seen the patent and movie you must find difference between announced patent drawing and shown gate setup:) Try to find it, if not , I will show it in my next message, you will be very excited:)Patent do not open all tricks! Now I have to run to my wife parents to say Happy new year:))
P.S. magnet field viewer card is grate tool guys, who are busy with gates developments - just buy it and you can drive your mind conc;usions very easy because you can see all magnet forces, lines etc. amazing staff!!!
Arrow
Hi guys, we made Howard R.Jonson patent 5.402.021 gate magnets not full and rough setup and have got this, shown below picture. Amazing field structure, now we have to think how to use sinwave form magnets fields at the gate and rotor.This investigation will go in parallel with general V-gate one as far we never saw such fields before and nobody here told us about such nice picture. Here we are a bit pity because we are starting to think that you are covering very valuable info.
Guess nobody here who are reading this topic want and need to see us successive in this magnet rotor project. If this is true we will stop supply further info to you guys, sorry. We are waiting your help if you know how to use sinwave magnet fields to get rotor running.
Is there anybody here that can explane why Howard R.Jonson gate not provided or explained us as better solution to construct magnet rotor ?
http://s61.radikal.ru/i172/1201/82/7c6064b2b32a.gif   - view part of magnet setup from patent
http://s017.radikal.ru/i434/1201/81/af9fb17a8a4f.jpg  - our ruff setup of megnets  based on patent drawing
http://s017.radikal.ru/i442/1201/1c/6040280a5eac.jpg - magnet fields structure
Truly
Rob
(Read 84113 times)
P.S. see our new flat V-gate that can take 1kg load
http://www.youtube.com/watch?v=RDM60mY4vlA
There are only 20 magnets 6x6x15mm neo magnets and general old HDD magnet because it has very interesting to us pole structure.
New gate has approximation of number of magnets.We learn how to reduce magnets, make larger gap between them and do not lose cinetic energy from gate.
(Read 84158 times:) hmm, 45 reads in 1,5 hour:) not bad stats:)
hund4444
H
i do you know what size of magnets he used
i´m trying to build on
PLEASE : i nead my answer as fast as possible!!!!!!!!!!!!
Thank you :)
Arrow
Quote from: hund4444 on January 04, 2012, 02:45:50 AM
H
Thank you :)
Hi hund4444
Welcome on board and Merry Christmas!
First of all I recommend you to read pages from 34 up to this one.http://www.overunity.com/10034/new-permanent-magnet-motor-on-youtube-from-roobert33/510/
If you will still be agree after examinations of such huge forum topic info  to construct this motor then take my drawings in Cad DXF format and try to construct.http://www.sendspace.com/file/nzamud It is revers engineering result of video and in scale 1:1.Based on this drawing rotor magnets have 1/2x1/2x1/2 size.64pcs and also it has 1 bar magnet... and one bottom magnets. Up to now I am trying such magnet size and did not get relevant result!.
If you have budjet about $300 and a bit more for this rotor parts and can wait about 12 days then go to this shop and buy magnets or find our your self relevant on line other shops for good Neo magnets.http://apexmagnets.com/?gclid=CP2Ohs_f96sCFcyHDgod2whdYw
To spent money you have to be sure what you are doing, so, if all this warnings did not stop you then you know what you are doing - wish you good start and good finish in this grate project Sir.
Why all this was written info to you ? because up to know from October 30 2011 we are trying to get good results and only pass the half way of it. Probably you will be more lucky than we are!.
Truly
Rob
McGiver30
the video's and pictures dont describe the gate or show it.. i am curious as to the arrangement of the gate.
and where can one get the fluxx paper at a decent price?
