Capacitive step-down transformer ...
Started by DeepCut, November 23, 2010, 07:08:12 PM
the_big_m_in_ok
Quote from: DeepCut on November 24, 2010, 11:33:11 AM
Yes hes using four 330uf caps to get 330uf.
Apparently one 330uf on it's own doesn't have the same effect.
Gary.
I've been thinking about that.  What "doesn't have the same effect", assuming the combined parts are all the same value and only the voltage tolerance is doubled on the multi-unit setup?
--Lee
derricka
Quote from: FatBird on November 25, 2010, 09:25:28 AM
In fact, WHY EVEN USE A RECTIFIER?  H2O Cells work GREAT on AC too.
The reason a rectifier is used, is to keep the hydrogen and oxygen produced separately at each electrode. With AC, you get both gases present at both electrodes. The resulting mixture of hydrogen and oxygen (sometimes called Brown's gas) is much more dangerous (explosive) than when the gases are kept separate.
The results can be tragic.
http://pesn.com/2010/06/18/9501662_water-fuel-research_Explosion_kills_inventor/
guruji
A guy said to connect electrolyte caps in series with same polarity together for step down. Can one post a diagram to see exactly how?
Thanks
