Magtap: harvesting electricity from a magnet!
Started by lasersaber, November 25, 2010, 10:07:23 AM
Hel
Lasersaber, I read your topic and I tried to replicate your experiment but
without success. See the PMH I built and used in the attached photo.
The core used is plain iron ø10mm. Unfortunately I had no more material
for the keeper so I simply used an iron horseshoe I previously made, but I
don't think it could make any difference, since both pieces adhere perfectly
and stay stuck well once energized. The µAmmeter I used is even more
sensible than yours since mine is 0-100 µA range. I also tried with the DMM
and the scope, sliding carefully to find a hot spot but I couldn't obtain the
even weakest deflection. I'm almost giving out.
Since I want believe you're not cheating us and you're actually reporting
a very interesting effect, I would strongly suggest you to investigate further
to understand the cause. Unfortunately I heard no more updates from you
or from any other people who could replicate the effect - just off topic posts.
The first thing I would do is reversing the coil polarity and check if the hot
spot keeps the original polarity or not. Then I would try substituting your
keeper with a flat one. Then removing it. May be you would be able to
measure something even with just the core without energy, coils and
keepers ? If it's real or rather some side effect, it has to be understood.
Hope to hear updates from you soon
Elena (a Testatika researcher and experimenter)
lasersaber
Hi Hel,
My uAmmeter is actually a 0-500.  I have built many more of these and need to post an updated video.  I have been able to increase the effect by about double of what you saw in my last Magtap video.  Even at that I do not think you would see it on a 100 uA meter.  I know others have replicated the effect, it's just the amount of current is so low it's very easy to miss.
Hel
Quote from: lasersaber on January 24, 2011, 06:21:24 AM
Hi Hel,
Yes I saw you ammeter is 0-500µA. But since mine has a shorter range, 0-100µA,
it IS more sensible. One ranging 0-1µA would even be ways moooore sensible.
Why you say the opposite ?
However, I again suggest you to follow a strong scientific approach. Please make
the tests I suggested ! Try to isolate the actual cause of that even little current.
lasersaber
Sorry, I guess it was too early in the morning for me.  Of coarse you are right.  I do not know what I was thinking.
I will continue to test the effect and share what I learn.  John Bedini has also tested the effect and seen the same thing.  He has some pretty good ideas as to what is causing it.
Hel
Ok. However I think it wouldn't be a so bad idea to at least measure the hot
spot with no magnetic field and no keeper to see if the current is still there or not.
I will stay tuned of course.
Cheers
