ORBO Technology Now Available To (Technical) Public - Any takers for €399?
Started by AquariuZ, November 28, 2010, 08:27:03 PM
AquariuZ
Taken from http://www.steorn.com/skdb/oedu/
Orbo Evaluation and Development System
For electronics and electrical engineers and specialists in magnetics and physics
System Comprises
    * 12 month Developer License
    * 12 month SKDB Membership
    * 1 Orbo Evaluation and Development Unit (OEDU)
    * 1 USB memory stick with test data
Orbo Evaluation and Development Unit will be shipped within 28 days of purchase
OEDU Features and Applications
    * Evaluate the core principle of Orbo Technology, which is that a time-variant magnetic interaction leads to a non-conservative energy result
    * Modify key parameters that adjust performance and efficiency
    * Prototype and develop products driven by Orbo Technology
Orbo Technology Developer License and SKDB Membership
    * Access the SKDB and its e-Learning modules to learn about Orbo and how to use it
    * Learn how Orbo technology works and how to build devices
    * Typically for electrical and electronic engineers, research and development teams, and specialists in magnetics and physics
    * Collaborate online and establish multi-disciplined research teams
    * Commercialisation requires separate license
    * Annual License and Membership
Download the brochure http://www.steorn.com/images/orbo-evaluation-and-development-unit-brochure.pdf
OEDU Support in the SKDB
    * User manual
    * Bill of materials
    * Board layout
    * Data analysis support
    * Optimisation support
Required Equipment and Skills
    * Proficiency in the use of a digital oscilloscope and associated data capture and analysis
    * Access to a 4 channel digital oscilloscope with a minimum bandwidth of 200MHz, minimum record length of 100,000 data points per channel and the ability to export the raw data
    * Two Passive Probes with a minimum bandwidth of 200MHz
    * One Differential Probe with a minimum bandwidth of 200MHz
    * One Current Probe with a minimum bandwidth of 200MHz
    * Access to Microsoft Excel 2010
    * Electrical measurement skills
    * Experimental data analysis skills
Please note the requirements.
AZ
PS: On the homepage there are now three engineers who claim to have measured 300% overunity.
Video: http://www.youtube.com/watch?v=_HKTYrVjEGY
AquariuZ
Quote from: happyfunball on November 28, 2010, 08:29:39 PM
So sick of the Steorn con.
Easy enough to verify now I´d say.
Appearantly you get a solid-state setup to test for yourself.
AZ
poynt99
Quote from: AquariuZ on November 28, 2010, 08:32:12 PM
AZ
Easy perhaps? Perhaps not.
Check out the equipment requirements. The 200MHz diff. and current probes are most likely out of reach by the majority. It's now easy for Steorn to say something like: "We're sorry you were not able to achieve COP>1 as we have, but you were not using the required equipment to make the measurements."
And to a certain degree, they would be correct. However, the question that still remains, at least in my mind is, has Steorn etc. really made accurate measurements, and is their test setup conducive to such?
We'll only know the answer to that if and when the information is publicly revealed.
.99
ElectricGoose
Quote from: AquariuZ on November 28, 2010, 08:27:03 PM
ROFLMAO  :D :D :D :D
Oh yeh...soooooo much overunity they can't even run a red LED load and the device itself unless a battery remains attached.  Still drains batteries but umm...OU??
Steorn is a pathetic little con.
E-Goose
