can any body write a tutorial how to build a Continuous electrical generator?
Started by shimondoodkin, May 10, 2006, 07:25:47 PM
shimondoodkin
which professional i will need. I dont' have at home metal processing equipment but i easily can find one to do it for me.
what to buy (where usualy)
what materials to use
what to do with them
what equations to use to calculate needed calculations to build a correctly working device
http://ntint.ntinternals.net/
http://www.freepatentsonline.com/20020125774.html
or
http://www.freepatentsonline.com/20030168921.html
(they are same)
you need to be registered to see pdf or images
Paul-R
shimondoodkin
as i understaned it is a metal ring or rings with windings like of a three-phase engine but they are double and with no air gap(a metal core in  the center) so the magnetical force go efficiently.
and it is working becouse of low resisstence of all the system and maybe with help of magnetical field of the earth.
Paul-R
This is a tough project to take on. Do you know
a school physics teacher who you liked? Or an
engineering student at University that you could
work with? Show them the patent and ask them to
explain why it will NOT work. (This sorts people out!!)
You need to form a team which will need:
1. knowledge of electicity and magnetism
2. knowledge of new magnetic theory inc Leedskalnin etc
3. engineering. Lathe work. maybe milling. pillar drill useful.
4. Coil winding. fairly easy.
5. Access to test equipment. Meters, simple oscilloscope.
Good luck.
