Splitting the electron stream
Started by gravityblock, November 30, 2010, 12:08:47 AM
ramset
We call them character flaws,they can be worked on[almost fixed].
Chet
Thanks Grandma
ramset
GeeeeZZZZzzzzzzz
You guys broke up poynts place!!!
Rufeans!!
Actually he has issues with the site right now!
Chet
Thanks Grandma
quarktoo
Yeah... that's what's going on... You seriously crack me up Ramset.
ATOM1
Hello !
Good to see gravity block is on the ball ! But all these fractions in equations to study an energy stream theory can bend logic into a cloud of entropic uncertainty ????? Electron structure is most important an electron is 2.2 trillionths the size of it nuclei so include a large nuclei and the electron structure expands but does not increase in mass ! An electron will have 2.2 trillion x y components and is why an electron can be split as y into anti electron. Please consider the electron as like string with its MF as a polarised position between x and y ... If this was not the case than a magnetic field would destroy it self and current would never pass..... The relationship of harmonics along a MF field line is most important to work out inductance over resistance if you wish for an instant transfer of energy. The way to go is forget old theory as a path to see what is truly happening as a reactive circuit and one that has a solid magnet in it will change the laws of resistance. To value the finite resistance one would have to include the earths magnetic field and its effect on all current passing if you wish to finally off set resistance to a point of 100% !
I have a small 500watt universal motor that operates at 4000 rpm at 00.1v over 00.01 amps it works by a reflection of coherence meaning the coils inside the motor emit a field function stimulated by the atoms surrounding the free electrons in the coils... The electrical energy being received into the coils is equal to the electrical field surrounding the system provided by the magnetic field of the earth...
Unity in terms that you are measuring will have a delay component in the equations and is why you find all these fractions in the numbers ! Also it is good to consider what is happening at the plank level and particle entanglements to help offset resistance in coil arrangements as quantum entanglement can affect a secondary coil that is at 2.2 trillion miles from its primary coil without a time delay or a loss of energy !
Throw that text book away ! Start again with one coulomb of electrons at one amp at one volt at one farad transfer this as energy from one coil to another at unity and without a time delay or energy loss ! The result can only happen if you use silver coated copper wire in the primary coil and iron wire with copper silver coated wire wound round it as the secondary coil !
Space is expanding so use it even the space between electrons in a current is expanding meaning that the distance between electrons will all be different ! This also is very important as the outer galaxies are moving at a faster rate of speed and is the same with all moving currents it is there for obvious that if one was to increase the rate of expansion a decrease in energy to transfer electrons would be the end result.. Formula for this is not available so it has to be written but not in the old way as ohms law does not include quantum entanglement or the expansion of space between electrons in a reactive circuit.
It also possible that our universe and all its mass share only one electron divide time and space into infinity and an electron can appear to be just one electron divided into one universe and would make the study of energy a single unit over time and space.. For a universe to come into being from nothing it would have to convert nothing into something and than bang ! I place my bet that there is only one electron !
regards
ATOM 1
ATOM1
o h dear no agreement on the maths or formula but they got more coils coming hahahahah technical spaghetti of un readable fraction obsolete mumbo jumbo ! So this technology is dependent on the fraction inverted over loop step up step dome this and that hahahah
Come on you can do better than that ! Where is the set formula to split the stream ????? An electron can be split, that is not new and it does not mean energy has be generated .... What is the dam point of all this technical data dumping ???? After you read it that read the disagreements it becomes a pile of crap.
Oh we have copied and confirmed and powered nothing hahaha Its so cleaver no one can understand it only the one who has written it and he will always defend it even if it don't equate to a standard logic ..
So you want to split the energy stream unzip the fabric of space and time ! Sorry mission impossible ! The grand-dio  dreams of lab experimentation's kids with toys and a bunch of academic money crunching mind bending fractional fanatics .... There is one universe not 1.03547548947578 divided in A + B quad static bull shit ...
You are splitting an energy stream it has mass this mass is moving at speed split it and then the mass is divided in tow streams now you want the mass to attempt to breach the speed of light to increase the kinetic energy .... Please don't include quantum entanglement your not using photons ................ Even if you did this through a split gate and observe extra amounts of electrons hitting a plat ect means its still only the same amount of electrons there is no real increase in mass ..... quantum jumping is how electrons exist around its atomic nuclei.
Divide space and time into infinity HOW MUCH SPACE AND TIME IS THERE ???? How many electrons is there are they all just one electron jumping around because time and space can be divided into infinity ? Try and catch just one electron stop it spinning isolate it and finally see what it truly is .... Than split it ! This way you don't have a problem trying to see the dam thing .......
The elusion is time and space is just tow points in time so forget that train going into the tunnel it does not turn into two trains but only creating a reflection of only one train .... Its known as the cosmic joker !!!! You need a big bang to create just one electron !!!! OK !!!!
Do you think you are GOD ???? Or Christ feeding the 5000 ???? Your basket is built of fractions ????? That would mean that Christ pulled out an ever decreasing size of fish or bread its the same stupid experiment that you are trying to achieve with a dumb ass electron.
You got no chance its not real energy its not real mass ! Only a master like Christ can ever do such a thing ! It is a super natural event you are looking for not one made in a lab ...... Now show me your split energy stream powering two trains or lifting two weights of the same mass ... Not two stupid light bulbs I want you to lift weight not liberating empty mass like a photon .....
We know old albert is right but he did not know of neutrinos or the harmonics of light ...... Apart from that you will never beat him not ever ...
ATOM1
