Splitting the electron stream
Started by gravityblock, November 30, 2010, 12:08:47 AM
quarktoo
Gravity Block,
You are obviously a pretty smart person but you are not seeing the forest for the trees.
The only math you need to understand is E=MC2.
You will find some shorted coils around magnets if I remember the latest orbo claim correctly. Those mystery magnets are doing compression which produces acceleration.
Had Einstein correct labeled his equation it would have been:
Mass To Atomic Energy Conversion = MC2
All free energy devices use mass as the fuel source and they all use acceleration to convert it into energy. There are lots of ways to produce the acceleration. Pulse compression just happens to be a simple one. See Thane Heins for a better example.
gravityblock
Quote from: quarktoo on December 06, 2010, 09:32:39 AM
Gravity Block,
Inductance in a circuit is the analog of mass in a mechanical system.
GB
quarktoo
Quote from: gravityblock on December 06, 2010, 05:53:55 PM
GB
Elementary my dear Watson. What is your point?
gravityblock
GB
Quote from: quarktoo on December 07, 2010, 10:45:19 AM
You need to first understand what your point was.  You said all free energy devices use acceleration of the mass as a fuel source to convert it into energy, and then I said the inductance in a circuit is the analog of mass in a mechanical system.  If you don't undertand my point, then you must not understand the point you were trying to make.  If you can't connect the dots, then the words escape me to show you otherwise.  Maybe the below equations will help you, but I doubt it, because you must first understand the point you was trying to make in order to understand the point I was trying to make.
GB
quarktoo
GB,
I was only placating you when I stated you were a smart person. It is obvious you have the ability to cut and paste, zero electronics background and took high school math.
Inductance in a circuit is an analog to mass in a mechanical model UNTIL you place a shorted coil on the inductor which is what I referenced. Perhaps if you were not trying to hide your lack of knowledge while trying to solve some puzzle you have no clue about, you would have seen that and not made two stupid replies.
Furthermore, Joseph Leedskalnin wrapped two shorted coils around an inductor and proved that a magnetic field can be conserved without current flow. So if your statement that an inductor is an analog to mass in a mechanical system is true, then you can explain why there is no friction.
Your pedantic understanding of physics and EM is not going to produce a free energy device anymore than your pareidolia driven self delusional math. I told you how and why it works and your replies only prove that you can't fix stupid. You got outsmarted by the empirical science of a man with a sixth grade education well over 50 years ago. Did you find the image of Jesus on a hot pocket? Maybe you can find yourself here:
http://listverse.com/2010/01/07/top-10-common-faults-in-human-thought/
