808 G6 OSIRIS ENERGY TECHNOLOGY
Started by osiris, December 03, 2010, 09:33:16 AM
quarktoo
You sir, are a legend in your own time! Even though you are nothing more than a defective floppy, as trolls go, you are the mark of excellence. Please allow the American Troll Society to thank you by translating this from defective Canadian floppy into English:
The chips are any JK flop flop chips such as the 74LS90 and the circuit is called a cascade generator. It is the same circuit that Stan Meyer used in his first fracture generator (International test report) to power the outer coils of the resonant charge choke (RF mixer).
Once the 2 or more signals are mixed together (Meyer's resonant charge choke) in an RF mixer and the heterodyned signal sent to an object like wire or water which removes the free electrons which make up the electron sea. Meyer called this "electron bounce phenomena".
The way it works is the high frequency sidebands knock the free electrons from the electron sea to produce a superinductive circuit which locks the water into a rigid state so it will fracture when hit with the opposite charge of voltage. It can also make a circuit superinduct such as the Leedscalnin PMH.
Keep them coming IST, the Earth is hanging by a thread and we could use a hero right about now. Your status has been elevated with the American Troll Society.
http://americantrollsociety.blogspot.com/2010/12/alterts-and-memos.html
http://americantrollsociety.blogspot.com/2010/12/most-wanted-list.html
EDIT -
Will you also be removing those free electrons using Meyer's diode and light bulb to convert them into photons? (electron extraction circuit?)
osiris
well if you liked the last one how about this mod to go along with the rf recharge ..
so i get the rf recharge working i send it to  CHRIP TO SONG  convertor  i now apply 1 pulse i get 4 overlapping .. i take that and audio amp it ..  bang it back around the ring and out to recharge the supply ..
ta duh!
osiris
quarktoo
Quote from: osiris on December 29, 2010, 12:20:17 PM
ta duh!
osiris
Translation:
Here IST is suggesting that you take the heterodyned signal and run that through a delay line which he bought wholesale and then recycle that back into the loop.
- end of translation.
IST you are one sick puppy. What will you call this amazing new wave? A "burst wave"? Sorry, Meyer already used that name. How about an "all frequency transmitter" Damn! The ham radio RF boyz alrealy used that one.
Well good luck with that. More importantly, the PHM coil of Leedscalnin becomes a rubber band with no EMF  - forward or backward - which is the friction on a circuit caused by excess electrons moved by voltage. It is also the loss that keeps all electronic circuits from going OU.
Since all electricity is mass to atomic energy conversion (evidenced by the amplified speed from speed of inductor magnet to speed of light) and since E=MC2, all electricity is OU. You just throw half of it away by using circuits that are at rest and stuck to the electron sea that pervades everything around you. That static is sticky business that produces heat and removing it makes everything move more freely and OU.
This translation was brought to you courtesy:
The American Troll Society.
Who also blew this frame too wide with that Meyer schematic for the betterment of science.
Only a licensed troll, a troll's troll, would have done that.
FatBird
