Thanks to ALL for your help!!
808 G6 OSIRIS ENERGY TECHNOLOGY
Started by osiris, December 03, 2010, 09:33:16 AM
markdansie
@oserisi (IST)
what is the device pictured  do. From what I see its a large stroage device using caps.
Appart from that is there any other purpose? Are you just going to make a huge JT device with it.
Kind Regards
Mark
energia9
Quote from: osiris on December 03, 2010, 09:33:16 AM
this is a basic power ring
i have designed this unit to be universal
meaning i can interchange the charger to work with over 10 diffrent methods ...
OUTPUT 10 KW 120VAC 86.9 AMPS  CONSTANT!
OUTPUT PEEK 20KW
this is also a power supply for a  UFO
OSIRIS
Hi osiris, i would be very interrested in your work, i hope you will share it for good,  it looks interresting. please could you teach me how a device can be achieved like the one you have?
Thanks,
Energia
Mk1
Making claims on hardware not even built yet , same old IST .
I hope it works out for you William , good luck .
ramset
I don't know what he did last time?
But I hope He behaves himself this time!!
Welcome friend,we need all the help we can get around here!
We don't speak in tongues anymore ,and all our crystal balls took a S$%t!
Well actually this guy Cletus took the last one!
So until further notice, where kinda flyin blind around here?
Can you share some more info on that monster?
Thanks
Chet
Thanks Grandma
osiris
hello all
thease are build pictures..  as it was built so you all can fully COMPREHEND IT
if i were to place a compleated device of this scale i would have noting but questions . and doubts .. so im placeing  pictures of the compleate build as i see fit !
regards
the title of the device  says its compleate operation ..
808 G6
there 6 15vdc 3000f banks = G6
there is 2 2.7vdc inputs 8 caps each 3000f 24 000 f 2.7vdc x 2  = 8 0 8
i have litterly 10 + compleatly diffrent tecks to fill my universal cap ring
i designed this ring to handle 900amp constant at 12vdc my invertor runs 15 - 10 vdc  @ 916 amp draw constant @ 10kw output draw at 120vac 60 hz....
so if you have followed ANY OF MY RESERCH through the years .. it will make perfect sence to what im doing ..
this is a low voltage high amprage high freqency device ..
osiris
