Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
markdansie
Quote from: helmut on December 25, 2010, 12:59:12 PM
Oliver and Valentin build this setup to show that there is no hidden Cable or extern source of power supply.
Until now Oliver did refuse to show the Vid to others The problem with tis setup was, that the rpms are very difficult to regulate.
There is no carburator in use. The hho Gas goes directly to the flange near the inlet valve. The only way to regulate the speed is by regulate the elektrolyser ( Anton ). Alternative one can adjust the spark timing.
If one is interestet to have one of this Generators, it is no problem to do a replication. All Informations are free available via overu.....de Forum.
The cost for such chinese Generator are not to high.
Some replication are in use all ready.
Feel free to read in the german Forum, or ask your Questions.
http://www.youtube.com/watch?v=rvSbJ9mG4Tk
Helmut
http://www.youtube.com/user/banditforfreedom
Thanks for the reply...so there are others running closed looped? If so where or how many?
Many people have a copy of this video already (I have one for several months)
So all tnstructions are avaialvle including all engine modifications open source?
I am happy to be made a fool of but these questions remain, especially when they are so reluctant to have basic tests done like exhaust gas analysis.
Thanks for your post , all information is always most welcome, I gather you have direct contact with them?
Kind regards
Mark
helmut
Quote from: markdansie on December 25, 2010, 02:10:48 PM
Kind regards
Mark
Hello Mark
Perhaps a exhaust gas analysis will be made one time. We know that water is the only source of energy. Shure one will find some carbon  because of the lubrication oil. But now there is more development important to build a working speed control. A second problem ist the ignition system. Some members are working with different systems to switch off the waistet sparc.
There are a lot of other vids.
I guess they will be kept hidden until the system is fit for public presentation. I know from guys in austria, they have a working Generator as well.
As next the team is working on another scale, where the Motor has a bigger flywheel , and a professional ignition system.
But every step needs its time
markdansie
Hi again,
i agree some carbons in the exhaust from oil, but how do you know water is the only source.
Mant people including myself have had engines running on HHO for years , not that hard to change ignition.
So is the austrian one closed loop?
many thanks.
I have dealt with many people making many claims for many years. Soome have had a lot of publicity and others are unknown...but I have yet to have one seen closed looped that have alloud people to do basic tests.
It is so easy to cheat...you can even coat the plates with some oil or add alcahol to the wateri n the bubble. Not hard to do at all.
I hope the Anton group are sincere but there reluctance to allow others to do basic measurements is of a great concern to me.
I was excited when I first saw the video, but as time went by it asked more questions than answered.
Mark
drspark
Hi group,
Merry Christmas
Regarding the little generator;
Looks like all they are missing is a stock *LP Demand regulator* and the breather below the air filter. Remount the carburetor, for its governor linked throttle butterfly valve. Use a stock LP breather and stock LP mix valve. Last will be a small pressure chamber on the cell side of the demand reg. Maybe a pressure limit switch. At 12 inches of water???
The Pressure chamber could be made from a empty hand torch bottle, Clear plastic Jar or a Very small tire inner tube.  A rigid chamber will make the limit switch easy, and eliminate the variac.
Where is info on their cell and driver circuit?
Thanks!
DrSpark
blavatsky
Where can I purchase the ANTON CELL here in AUSTRALIA ?
