Captret and Tesla switch
Started by plengo, December 27, 2010, 06:56:36 PM
plengo
A little update with my logging of the voltages.
I am also starting another captret circuit (version 8) where I am extracting about 46ma on average 16 volts (about 0.736 watts/h of power). I am not sure about this one. Battery is very depleted so I will have to wait and see it.
The captret of the videos is working wonderfully well.
Fausto.
plengo
my latest voltage is: total both bateries = 19.6782v, battery B1 = 9.71v and B2 = 9.97v.
LED is a little bit brighter very noticeable to the eye.
I dont understand really why this one setup works so well.
I have been playing with the captret and there is a lot more than we can see. It is almost as if it has 3 caps inside and you can move charges from 2 of the interval virtual caps back and forth at any speed and not have any loss at all except the normal loss any cap looses when once charged let it sit.
I know that one will always loose around 50% of the energy when moving a charge from one capacitor to another (at least that's what the formulas on the books teaches) but with the captret one can move the charges back and forth on the internal virtual caps breaking that law.
I am able to pulse from those virtual caps and light 2 LEDs without any noticeable loss on the main normal poles of the cap and neither of the 2 virtual caps. It is very strange. I think this is one of the keys of the understanding of how the captret really works.
I have not been able to replicate my first currently running setup yet.
Fausto.
aaron5120
Quote from: plengo on January 01, 2011, 12:27:22 AM
Hi plengo,
What do you mean your first setup? Do you have another variation of the setup than the one we saw in the photos you uploaded already?
I have bought a lot of caps in order to replicate your experiment, except I want to try NiMH rechargeable batteries instead of Lead acid ones. Maybe the charging time will be different. I have to adjust the duty cycle and also the relay switching time. I plan to use a reed switch in place of the relay( I do not have one that works on 12V DC).
How did you came across with the present caps value (6000MFD)?
Thanks for sharing with us your discovery, I think this is the most important discovery in 2010 in the free energy community: the Captret effect or the "Plengo effect" in honour to its discoverer.
aaron5120
plengo
Hello aaron5120,
the 6000mfd is just what I had around. I also played with many different caps sizes and shapes. Bigger better and higher voltage also better.
Make sure you use an LED that will show light on very very low amperage like 1 to 5ma. The effect is charging the battery while I am consuming that little power and getting light.
My second design is the one I am changing as I am learning about this captret. The FIRST design is untouched running for a week now and I will leave it running untouched for many more days to come so that it will show without any doubt that it is OU and free.
BTW, the captret was found and published publicly by a user named "ibpointless2" not me, so it should be called the ibpointless2 effect.
I also agree this has been an amazing discovery this year of 2010.
Fausto.
ibpointless2
Quote from: plengo on January 01, 2011, 12:06:28 PM
Fausto.
Plengo I do thank you for being such a honest man.
I don't think people would like the "ibpointless2 effect", they might think it's a joke. I would say use my last name "Lovelace" but to some that is also a joke. Maybe use my initials "SLL Effect" , but i see the "Captret Effect" as best.
Plengo have you figured out a switching to use? I know it will be hard to build one, but the simpler the better. I also have a good feeling that transistors should not be used, unless used in a different way. You're probably asking why i would say that? I believe that our current setup of electronic components are setup to fail at getting overunity or free energy, they work with the idea of a closed environment. Sometimes the component needs to be adjusted different to get on the right track for overunity, I've shown that with the captret. I've have a few ideas brewing in my head and i'll post one if it truly works.
Some people are worried that i've stop working on the captret, but i'm really gathering a better understanding of it. My Goal has been to get to the bottom of this effect and i believe i'm getting close. I can make home made captrets with 20 captret layers, each producing their own power. I've got captrets powering themselves and other things, and when given a load will output more power over time. We have barely scratched the surface of the Captret effect, trust me it gets more crazier than self charging batteries.
Keep up the Good work Plengo, I really do enjoy watching the videos.
