Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
e2matrix
Quote from: wings on February 05, 2011, 12:24:25 PM
this one OU for sure:
http://www.youtube.com/watch?v=EE2S_so0dR8&feature=player_embedded#
What does that have to do with OU or the Joule Ringer?  A guy playing an electric guitar ???    Did you get your link right?
resonanceman
Quote from: Magluvin on February 03, 2011, 10:36:07 PM
Hey Resman
Im in the process of building an electric car, a fiero, and been studying it for a couple years.
In this vid the vehicle seems to be in a very very low gear, and believe it or not, the 12v bat will drive that motor. Not to 20mph, maybe only 10mph.   I work at a corvette restoration facility, and had a chance to sit on a rolling chassis and make it go by just turning the bare axle u joint on the differential by hand. I was testing this to imagine a Warp 11   an 11in motor from Netgain driving the drive shaft by bypassing the transmission, as is being done out there already.  My fiero is getting a Warp9    9in motor.  I will be able to do bout 70mph and have tons of torque in the bottom end, as electric motors are opposite of gas engines.
But just a bit of info for thought.  Im not saying he is not doing the power conversion that he is claiming, as in using rf equip, but always be wary. ;]
According to Tesla, an ac induction motor would be best, and since this guy is into rf, an ac motor might be better.
Mags
Mags
good luck with your project.
I looked at the netgain site........interesting motor.
gary
Doug1
http://www.l-3com.com/edd/products_traveling_wave_tube.htm
These tubes work have been working for some time are in use and the working theory behind them can not be argued. Less all your cell phones and microwave ovens are a mass dillusion. How they work physically and for real in their most basic princable should be noted to scale and adjust to other levels of energy.
  Would you really pull a cold beer from an RV refrigerator which works off amonia absorption without a pump and claim it can not work without an electric pump?
resonanceman
Quote from: Doug1 on February 06, 2011, 06:28:30 AM
Doug
The animated gif on  your link is very good........
Do you have any experience with these tubes?
Do  you know how  powerful the magnets along the tube are?
The way I see it working is ....... the electron gun  shoots out a beam of electrons........ these electrons  travel down the tube with magnets around it.......the electron beam  has to fight the flux of the magnets all the way .......this slows it down and  adds to its effective energy.
When  the  beam reaches the collector  it is transformed  back into usable energy.
Is this  how you see it working?
If this is right it may  be possible  to make something similar but without the high tech stuff........like the electron gun and the collector to turn the beam back into a form of energy we can use for everyday stuff.
While looking for a way to get the effect of LARGE toroids without actually using large toroids I came up  with what I call a candy cane coil....... I named it after a candy cane because if you wrap  a few windings  around each toroid of a string of toroids with all the wraps in the same direction the windings progress around the string of toroids like the stripes of a candy cane.
Using  a long string  of toroids on a candy cane coil  you could set up a wave structure similar to what is described in your link.....A JT could possibly be used but I would think you would want a signal generator or something for a more stable frequency.
The toroids would  look alot like the magnets in the animated gif in your link.....except they would have the windings spiraling around them .
The second  part  ........the magnetic  field could  be created with a tube, some magnets and some tape .......
If magnets were stuck to a piece of tape  all with the same poles facing the same way....and that tape wrapped around a tube......it would make  a tube with the N pole either on the inside of the tube or the outside....I doubt if it really matters
anyway ....... if the candy cane  coil is put inside the tube  wrapped with magnets ......the  magnets  will subject the toroids to a specific  flux level..... overcoming this flux should slow down the pulses traveling along the candy cane coil at some specific power level.
It will be a balancing act......... to much power and the flux will not slow down the pulses much.........to little power and it will choke the pulses off.
Others here have tried attaching magnets to toroids and some have seemed to have some success.
In my tests sticking magnets to toroids  mostly  just raised the turn on voltage of the JT
running  a toroid coil in a magnetic field should be much different than sticking a magnet  to a toroid.
Sticking a magnet to a toroid should  act kind of like cutting a gap in the toroid........ the magnetic domains saturated by the magnet are effectively gone from the toroid as far as the circuit is concerned.
I would think with this device we would not want to saturate any of the toroids with magnetic flux...... All we would want to do is line up the magnetic domains and give them a little resistance to change .
If the right balance is achieved some of the flux of the magnets should be entrained by the pulses.
I think JT type pulses would work best....a high amplitude spike would have a wider bandwidth than standard RF making the flux level of the magnets less critical.
gary
kooler
11volts..
3300uf cap..
flyback coil..
no bifilar..
http://www.youtube.com/watch?v=ATMDcRL3vF0
robbie
