Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
Doug1
Graphite will enable you to determine if you are actually influencing the electrons with the outer magnetic feild of the coil and not the conductor meterial.Besides pencils are cheap.
resonanceman
Quote from: Doug1 on February 13, 2011, 09:14:37 AM
Doug
I am not sure how graphite can show  if you are influencing the electrons
I also have some questions about the parts you talked about using
The parts you describe are very small and for the most part not low resistance........
One magnet may be enough  to prove something is possible........but the original unit had many magnets....It seems to me that if you use 1 magnet or dozens  you still only want to have enough magnetic flux to slow down the pulse............the big difference is how much time  you have to entrain then capture extra energy
My plan was to have my magnetic tube at least a ft long....
gary
Doug1
The pitch or angle of the feilds created from the coil around the conductor will have to be worked out experimentally .Tuned for the intended application.Thats why small parts.Working units are very small to begin with only a few centimeters for microwave range. If the parts you already have to play with are large then go for it. There are only two magnets required one for each termination of the outer coil which is fed with a signal as well. I beleive the magnets are to polarize while the signal is for bunching up the wave guide so it can grow in magnetic amplitude at the ends.
  Im still looking over the letter from Otto post.Very interesting stuff regarding materials.Not to much of a shock when you think about it. A vacume tube uses materials that work well in a vac. That doesnt mean there are no materials that will work well in open air just means they chose not to go that route back in the day.
resonanceman
Quote from: Doug1 on February 15, 2011, 06:40:31 AM
Doug
Are you sure that there are only 2 magnets?
I have watched the animation in your link several times
The word Magnets is a yellow color ........for a second or 2 what looks to me like a row of ring magnets is highlighted in the same yellow color then the magnets and the word magnets is pulsed a few times.
gary
Doug1
Your correct Gary
I found autobiography on one of the inventors. The evntually ended up using farite beads with washers between them to create the effect of multible magnets.They also played with alternating stationary magnets between beads. It's a cool read so passing the link to ya.
http://www.smecc.org/john_r__pierce____electron_tubes.htm
  I finally stumbled on the Daniel Dinggle vid where he clearly states that his gov could not help him or even consider getting involved with the HHO car because they have a signed agreement with world bank that prevents such efforts.Very depressing. I wonder if there is a copy of chaarter for the world bank floating around to confirm this is part of their charter. It would be nice to know with validation who's door step we should be crapping on and making it public.
