Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
Lynxsteam
I just checked the amp draw off a typical 12/120 volt inverter to power the same 14 watt CFL.
1.875 amps or 23 watts to power the bulb.
I also tried powering my Teslamp circuit with 12 volts.  .372 amps or 4.68 watts, not any brighter than the 9 volt.
conradelektro
@SkyWatcher123:
Great, some more air coils! A retro trend is starting.
The nicety of air coils: one can build them at home rather easily and they seem to swing at a higher inaudible frequency above 100 KHz. May be the frequency comes down once really huge coils achieve an inductance comparable to ferrite core coils. But I hope that with a careful design one can build a more delicate circuit with a frequency above 100 KHz.
I have some smaller CFLs which only need 3 to 5 Watt at the 220V mains and seem to glow bright enough to be useful with 0,5 to 1 Watt on a super Joule Ringer type circuit. A retro lamp has to be dimmer to underline the 19th century atmosphere  ;) .
Greetings, Conrad
SkyWatcher123
Hi folks, Hi conrad, i tried the setup, though I think the 24 gauge main tower coil is too thick of a gauge wire to get the needed high voltage for the cfl.
I have 30 gauge wire, I am going to rewind the tower coil, will take a little while to wind it again.
peace love light
tyson :)
Magluvin
Quote from: SkyWatcher123 on May 06, 2012, 01:49:53 PM
Hi folks, Hi lynxsteam, thanks for sharing the lamp idea.
I happen to just finish a coil tower yesterday, though it has 24 gauge wire and is 9-1/2" tall X 3" diameter, it's a pringles chips can with metal bottom removed.
I'm going to make some tests starting with 24 gauge bifilar wrapped around bottom 1/4 of coil tower and see how it goes with your wiring setup, then try some different things just to see.
Here is a pic of the pringles chips tower.
peace love light
tyson :)
I wonder if the foil inside the pringles tube is conductive. Might be some loss there.
Pringles pizza flavor. ;]
Mags
Magluvin
Also those rings at the top and bottom of the can. They will suck the energy out before you can say "Pip"   Get rid of those and make some scores in the inside of the can length wise. it should do, but i would even try to peal that inner layer off if you can. Ive seen setups with thicker wire and fewer turns do the job. Give it a try before you unwind. ;]
Mags
