Bob Beck Protocol for curing AIDS and Cancer
Started by matthew6060, January 05, 2011, 04:18:04 PM
Great circuit les banki, but its size may put off a lot of people. Unless you give them the pcb and parts to solder  :P . The design could be made a lot easier. And I would recommend a separate unit for silver making and blood electrification. My old silver maker had also a magnetic stir. I'm about to rebuild it as it's in pieces now. The current regulator is handy.
TheOne
I ordered all the part needed from ebay mostly and the silver wire.
I only have problem with this part  18v zener diode NTE5027A, is they are some equivalent for this part?
Thank you! I hope I will able to build it in the next 2 weeks!!
NTE5027A: ZENER DIODE 18VOLT 1/2W 5% Do-35
I find this on ebay, this is the same? http://cgi.ebay.ca/20-18v-Zener-diode-1N5248B-volt-500mW-DO35-ROHS-/250554445342?pt=LH_DefaultDomain_0&hash=item3a56356e1e#ht_539wt_833
18 Volt Zener Diodes
500mW in a DO35 glass body axial case
Les Banki
broli,
Keep in mind that ALL my designs (going back about 15 years!) of these "gadgets" were originally for manufacturing (production) ONLY!
They are still being produced.
(They were NOT intended for home constructors!)
If you read my attached file perhaps things will be a little clearer for you!
I also have SEVERAL models of colloidal silver makers ONLY, from 200 ml to 25 litres commercial unit!
Best regards,
Les Banki
screaminvern
Quote from: TheOne on January 09, 2011, 09:05:04 PM
1N5248B looks like a good match. This is where I check my parts:
  http://www.datasheetarchive.com/
Can we perhaps do a community effort in designing a cheap colloidal silver generator (CSG) and blood electrifier (BE).
Some specs could be:
CSG:
0.5mA current limit
30V operation voltage (can be from a cheap 10$ laptop charger)
555 timer to switch double throw double switch relay
led to indicate when operating at current limit
Optional:
magnetic stir: 12V computer fan with neo magnets glued to it. Fed from same supply.
BE:
50µA-100µA adjustable current limit
adjustable frequency 1-4Hz
led to indicate current limit is reached and the device is actually working
Not to sure about voltage here though.
This should get us a decent setup that can be spread around OU.com.
