Bob Beck Protocol for curing AIDS and Cancer
Started by matthew6060, January 05, 2011, 04:18:04 PM
Les Banki
All,
When I first posted in this thread, I was only trying to help!
broli,
Please your self.
If you want to "re-invent the wheel", by all means, design your own stuff!
However, for the benefit of others here, I have attached a circuit diagram (BCSM6, which stands for: Basic Colloidal Silver Maker) and a Word document describing its features and specifications.
Since this circuit uses less than 5 mA current, when a 24VDC plug pack is used with such a light load, you have around 30VDC.
As for my 'blood cleaner' design:
If you don't want electronic ON-OFF switching - leave that section out.  Same with the timer and buzzer circuits-if you don't want them - leave them out!
If you have read the document I attached previously, you should know that in that circuit current IS limited!
Further, you missed the point on the advantages of having a COMBINED blood cleaner AND colloidal silver maker.
You can argue all you want but the fact remains:
the COMBINATION unit is the most ECONOMICAL solution, just as I explained in that document!
Best regards to all,
Les Banki
TheOne
I followed the beck device last version from 1996, it a simple schema, I ordered everything, i hope to receive everything this week or next and be able to test the device ASAP.
I hope that will help to restore my immune  system and resolve my diabetes! since this crap is related to the immune system i think that can help.
Quote from: Les Banki on January 10, 2011, 06:32:38 PM
All,
broli,
Please your self.
Les Banki
No need to reinvent the wheel, which is even hardly that in this case. Your last circuit is much more in the spirit of what I asked. I would add a timer circuit and a DPDT relay.
I'm trying to have a circuit with very common components and which is not too daunting for noobs to built and at the same time is modular and adaptable. Even a zener diode is imo unnecessary. The need to both devices in one is unnecessary. In fact it could be disadvantageously if you want a portable BE or use it discretely at work.
quarktoo
Quote from: TheOne on January 10, 2011, 09:07:19 PM
Diabetes along with most other diseases are curable but the cures are being suppressed. Caused mostly by hydrogenated oil which turns to a plastic like substance within the eyelets of the pancrease because it is a like a hydrogen free radical that bonds to stuff. Got olive oil?
The way it is cured is they inject capastacin directly into the pancreas, wait 4 hours and inject a polypeptide called substance P and in 24 hours, type I type II gone!
You are never going to see that cure hit the streets. Disease and small arms conflict is what eugenics is based on and how they depopulate people and genomes they deem inferior.
A Canadian researcher came up with that cure. The likelyhood of colloidal silver or micro currents pulsed through the radial and ulnar arteries helping diabetes... Have not heard of that one before.
Quote from: quarktoo on January 11, 2011, 07:56:13 AM
Can you pm me the information about this researcher please. My brother is a type 1 diabetic.
Edit: Finally found a lead http://www.naturalnews.com/021345.html It's capsaicin not capastacin.
