Perpetual batteries from Vasilescu-Karpen
Started by exnihiloest, January 08, 2011, 06:20:57 AM
profitis
What is your anode(-) made of and what electrolyte are you using @d3xor
d3x0r
Quote from: profitis on July 22, 2014, 07:48:45 AM
graphite plates ....one up in chunks ... aluminum sheeting ... calcium bicarbonate
the aluminum is negative
profitis
This is galvanic corrosion without a doubt.aluminum is way too reactive to use in a karpen cell you will see gradual pitting of the anode under microscope.I'm going to give you one of my secrets to try out if you want d3xor then you will be ahead of murray on youtube but you will need to get hold of a chunk of pyrolusite mineral(MnO2) and large piece of nickel coin or spoon or sheet.
d3x0r
Quote from: profitis on July 22, 2014, 08:16:38 AM
Hmm Yes I might see that.
also it seems I can just use native tap water.
might be able to observe a faster decay with thin strips of aluminum foil
Edit: can you give me a rough sketch of the reaction and products?
profitis
