DRJ200 》100% CNF reactor for home use.
Started by Doctor No, January 09, 2011, 06:32:06 PM
Doctor No
Quote from: gauschor on November 05, 2011, 09:36:33 AM
Please tell me more about the upcoming WWIII scenario  ;)
And besides... are you really sure it's the russians who own these "invisible" planes? I somehow doubt that.
I'm sure now that we have avoided War thanks this:
http://nspap.livejournal.com/1732.html
(But no one can be sure to the end really).
I think but there comes very bad time everywhere.
First EURO sinks, than our Zloty (PLN) till Summer.
Than in Autumn US Dollar goes through chimney.
Doctor No
This and next year possible is a short, 10 unit serie of model 2013 to built.
Here are technical specs.
S=Siemens, H stays for Helmke engine producer.
Engine power
[kW] .... .... .... ... .... .... .... ... ..11 .... .... ... .... ...15. ... .... .... .... 18.50
Heat production
[kWh] .... ... .... .... .... ... .... ...16.00 .... ... .... ....22.00 .... ... .... .. 28. 00
Electrical power : [kWh]
S/H....................................14.40 /14 .00 .... .19 .50/ 19.00 ..24 .50/ 24.00
Heated room: [m2 ] (by 30/75 kWh norm)
... .... ... ...............................1. 300 /520 .... ... 1. 800 /700 ... .... 2.300 /900
Total mass
[kG] .... .... ... .... .... .... ... .... ..115 .... .... ... .... .... 132 ... .... .... ... 150
Process efficiency (%)
S/H .... .... .... ... .... ...............110/114 .... .... ..112 /115 ... .... ...114 /117
Mechanical efficiency (%)
S/H .... .... ............................194 /194 ... .... ...195 /195 .... ... ...201 /201
Both engine types are of IE2/2011 Euronorm.
This norm will be valid only through 2013.
From 2014 the new IE3 Euronorm for electrical engines goes into live.
Engines of this will be some 4-5x more in price than todays IE2 types.
Only to say, small 1 kW engine for wash machine, will cost 1.000 USD, even 3x more than today all the wash machine.
Everything will be much, much higher in price than today, even if there will be new money already.
It is proposed change ratio 5EUR:1 DM.N (German Mark New), but prices for most important raw resources will stay on today level.
Only wages go down.
Technical datas for engines model 2013 :
Engine Siemens (S) /Helmke (H) ... .... ...
.................................................11 kW/400V ..15 kW/400V... 18.5 kW/400V
Power nominal/real [kW] 50Hz ....11/8 .25 ... ....15/ 11.25 .... .18.5 /13 .9
Revolutions [rpms/ min.] ............. 2.955 ... .... .... 2. 955.. .... .... ..2.955
cos "&" (S )/(H) .... ...................0 ,87/0 .90 ... ..0.88 /0. 90 .... ..0 .88/ 0.91
Current by 400V [A] docs/practical
Siemens IE2. .... ... .... .... ....20,50 /24. 00 ... ..27 .0/ 32.00 .... .33. 5/ 39.50
Helmke IE2. .... ... .... .... ....18 .70/ 22.50 .... .25. 10/ 30. 20 ... 30. 80/ 37.50
mass [kg] ... .... .... ... .... .... .... ... ..68 .... ... .... .... .... ..85 ... .... .... ... 104
Loud level [dB] S/H .... .... .... ...70/ 81 .... .... .... ... .70/ 81 ... .... ...70 /81
IE2 engines from Siemens make 16x small loudnoise than previous EFF2 (IE1) class engines.
The workhead will be insulated with 10-15 cm foam to have 99% heat efficiency and to reduce noise of nuclear reaction.
The clutch will be for to make distance from engine for it and have better possibility to send workhead alone to proving.
Doctor No
This who would like to know more about effectivity of NSBRJ (DRJ.200) model 2013 i inform that, this is about 30 to 40% (depending on engine and power) more effective over simple electric heaters which cost some 25-30 EUR's (3 kW).
But it is also same way more effective over each heat pumps.
I mean winter conditions with under (-) 10 temps where users of heat pumps should turn them out for prolonging theirs lifetime.
This comparision of various todays fuels and heating means please choose (only in polish language): http://bioenergia.energo24.pl/189,porownanie-nosnikow-energii .
Generally, by gas it is maximum to  30% to achieve, by coal, newly developed in Poland chimneys some 20%. The last figure, although some 2x better in comparision to old types from 60/70-es is 3x weaker than by industrial, electric power station also, which makes >60% of heat from chemical energy of coal.
Of course, turbine and generator losses make it into electrical energy between 30-33% overall.
So as You see, coal burning in home conditions is not very efficient.
Same is in practice with a gas.
Using of conventional, cheap electric heaters which have 85% efficiency bound with cheap "night" mode electricity prices, was always known as the most efficient way of heating.
The only problem was this, that old homes technology required much of water reservoir volume because of much heatpower consumption.
Everybody was more convienient to waste homespace with coal than with water tanks. Really, it is were logic lost was.
But now, especially with new homes which are build according 30 kWh/sqm rule, they consume some 4x less heat energy than old homes.
And by polish price conditions, when comparing the best 30% gas heaters to 85% electric simple heaters, this last mean is some 33% more cheaper over gas heating.
You can use this next comparision for own purposes:
electricity price 1 kWh night mode =0.07 EUR or 0.09 USD
gas price 1 m^3 =0.40 EUR or 0.55 USD
Generelly, when price of 1 m^3 of gas is 6x higher than "night" 1 kWh of electricity, You have well over 30% less to pay for heating.
And with our NSBRJ which 30-40% more effective over convienient electric heaters, it is better than 2x cheaper.
:D
http://bioenergia.energo24.pl/118,narodowo-spoleczny-biologiczny-reaktor-jadrowy
The smallest one today, 11 kW engine attached, is born for 1.300 sqm/30 kWh or 500 by 75 kWh.
This last are old homes insulated with 12 cm foam and old types of PVC windows.
So as You see the smallest is for some 8 newly built homes or 3 older type.
The biggest engine 18.5 kW makes 2.300/900 sqm.
It is 18 to 6 homes to divide cost of 4.500 EUR (6.000 USD) between.
To this comes possibility to cure peoples with free, rest, energy of tachyons, as is by the DRJ.600 already (CNFR.600).
http://nspap.livejournal.com/1398.html
Because of this, abroad as well country folks, we limit to only specified persons/groups of potential users.
Free Energy of DRJ.200 is 100 Millions greater (10^24 eV) over big and costly LHC in Switzer-Putzer-Land.
By CNFR.600 it is well 3x greater.
Dr. Adolf Nowak
NSR POLEN
60-143 Poznan 8)
Hello Dr.No,
www.smstechnologies.ecrater.com  show us an other solution for a cheap and efficient heater,
electric forced air !
495US$ for 1400-1600sqft heating  area !
Another possibility could be to modify/optimize this forced air-heater with the HTM-material from     www.canlaser.com    .
A cheap and very flexible solution,do you agree ?
Sincerely
              CdL
p.s.: to compare with conventional values here :       www.sonnenkoenig.ch
        2000W -old-/1500W-new- construction , 20sqm area
        30 degrees Celsius temperature spread
         Germany, average electricity price,night mode 0,12 EUR/KWH netto (+ monthly fee)
Doctor No
Not at all:
http://eurocosm.com/application/products/swimming-pools/pool-heaters-GB.asp
I don't know how much it costs, but here in  Poland, 3 kW heater as this:
http://atinstalacje.pl/opis/2113986/grzalka-elektryczna-3-kw230v-54.html
costs 25-30 EUR (33-39 USD).
With additional 2x 200 L water tanks (each 100 sqm/75 kWh norm), also total invest cost of about 1.000-1.200 EUR (1.300-1.550 USD) You achieve >30% cheaper heating costs over the heat pumps, gas, coal, everything.
Not saying about local ecology and convienience.
This solution is know for more than 110 years, but it will take some centuries when people accept this knowledge.
I only wonder, how many civilizations will take to understand our CNFHR solution?
On our own new class IE.4 magnetic electric engines it makes 170% efficiency.
Also 2x better over all this electric heaters.
3x less cost than gas, coal today.
But this is not the last word in this solution.
But we had abandoned it till 2030 year.
Happy now? :P
