Simple Cold Fusion
Started by aoi3610, January 13, 2011, 07:56:03 AM
aoi3610
Hello all,
I had put the details of this device on another site, but one of the users there stated that I should pop it in here.
I am looking for thoughts and input.
Please do not ridulce it, I have answered every question a ridiculer could think of and smashed every question.
Whilst the device is stupidly simple, that does not mean it does not work.
I have no interest in the Overunity "prize".
Here it is, the EYE of HORUS.
No doubt the skeptics will say, blah blah blah
THIS IS NOT A HOAX.
This is Aladdin's Lamp, it Produces Phosperous at the top to burn.
The Key is GOLD plating the Pot before you heat it for true "COLD" fusion, however, it works as HOT fusion in just plain Aluminium.
YOU MUST TAKE NOTE OF THE POTENTIAL SAFETY ISSUES NOTED AT THE END.
YOU DO THIS AT YOUR OWN RISK.
NADA NADA NADA.
Had to re-iterate this:
If this is doing what I assume it is, then there is serious risk here.
I DO NOT want to hear that the next spate of "Unexplained Deaths" is through unfortunate experimentation with Cold Fusion.
OK.
Here it is, step by step:
Take 1 Can:
http://picasaweb.google.com/lh/photo/tQDC4DrEp7m3iS50VnNyH7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
Chop off the top. (mind your fingers.)
http://picasaweb.google.com/lh/photo/qzbzkYppkMnOkElqwzMMD7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
Beat the bottom into a "Dome". It is possible to go further than this.
http://picasaweb.google.com/lh/photo/knWiRa6e5_yInRk08nYg-ryL4mXGIzqrcL_TTyxlvQo?feat=directlink
Mark out the Can. For Fill Location and folding lines.
http://picasaweb.google.com/lh/photo/l_8MkPWH5bHq64y11rh9WbyL4mXGIzqrcL_TTyxlvQo?feat=directlink
(Fill levels are)
Bottom Radius = 65mm (1/2)
1st Fill Point = 32.5mm (16g Lead)
2nd Radius = 32.5mm (1/4)
2nd Fill Point = 81.25mm (4g Tin)
3rd Radius = 8.125mm (1/16)
3rd Fill Point = 101.5mm (0.5g Silicon)
Fill to top.
Crimping the CAN.
http://picasaweb.google.com/lh/photo/pZfI5XvAuDZGrRsMZ6JGUbyL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/tO0DnVCMIehFWuXK8QJWaLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/IJSCqQRDbR87CiZX0UVpoLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/xEMjo6trc1dpV8zxV551v7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/yNwGbGQuvnLBQHHTX0JBULyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Next you can see where i've "cut" the top slightly so I can close up the gap. (Heat retention)
It would be nice to remove the fins, but it is not easy. I have tried.
http://picasaweb.google.com/lh/photo/zuxkXzEJ0YDfw8UbTaElBLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Good Set of scales and a Pot: Then weight the items.
http://picasaweb.google.com/lh/photo/gQGXOHIm_8KPW3gdI1J_hbyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Lead etc.
http://picasaweb.google.com/lh/photo/PsR0bltfzA4OkWyWiEnmd7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/bfIGdhBOMD34d4REjdHZMryL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/AuTODSr5WaFNvsX6qgU2yLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
This is where you learn how good an insulator dry earth is, melting the bits.
http://picasaweb.google.com/lh/photo/3P23owqeOoR9oweJg9NLy7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
http://picasaweb.google.com/lh/photo/oZthN8TGgYXIx7Tp3xBzo7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
Bit blurry, but you get the idea.
http://picasaweb.google.com/lh/photo/tXlVUaFeHRG1f1majvtdW7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
Now, for this attempt I had no Gold plating, it was like 2nd Jan. So I improvised.
Just a speck. 1/64th (imagine, that's all that's needed to plate the can!!)
http://picasaweb.google.com/lh/photo/c_z2Q1PYEoZ0lZYHfOwkoLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
So, filling. Starting with this attempts "improvising. (It needs plating really, which I am about to try)
I put just a dusting of Earth on the bottom of the can. (I had given it an extra punch in the middle at the bottom to accomodate this.) The Eye of Horus 1/64 does point at this place? That was my thought at the time.)
The blip of gold is in the middle.
http://picasaweb.google.com/lh/photo/AyL4IWpjHoLiV1uR3hrQKLyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Fill to the first point, 32.5mm with Dry Earth and then drop in the Lead.
http://picasaweb.google.com/lh/photo/Ps-xpeIL6OwijkG1aGFRx7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
Fill to the next point with dry earth, 81.25mm, then drop in the Tin.
http://picasaweb.google.com/lh/photo/5D_yeork5rl6wagZDH5sibyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Fill to the next point, 101.5mm, then pop carefully in a straw.
Fill to the top with dry earth, leaving the straw in place.
http://picasaweb.google.com/lh/photo/ow0kwyu0P1hSbGb8n1QIlryL4mXGIzqrcL_TTyxlvQo?feat=directlink
Put the sand down the straw with a "paper funnel" or similar.
You should end up with something like this?
http://picasaweb.google.com/lh/photo/r4bFglwGkG8EZ6uy6eg4gbyL4mXGIzqrcL_TTyxlvQo?feat=directlink
Pop it somewhere hot, Gas mark x - (250 - 300 - 400 etc.)
NOT LIKE THIS:
http://picasaweb.google.com/lh/photo/Pm5U0Tcb059WCpqsKa20E7yL4mXGIzqrcL_TTyxlvQo?feat=directlink
The can melts at 600C!!
I have also used the oven, up to about 400C, As long as you like I guess.
The Earth goes really really BLACK once it get's really really hot 4 hours or so at 400 degrees.
It will then allow you to "light" the torch.
WOW, there is nothing in the can to burn, yet still it lights.
IT STAYS HOT FOR A VERY LONG TIME AFTER YOU REMOVE IT FROM THE HEAT.
Dry Earth is a very very very good insulator. The metal will take several hours to cool.
Poor ICE COLD water on it for 5 minutes.
Then watch it burn your hand.
CARE.
however, remember.
NEUTRON Radiation, potential hazard?
If it works for you, then it is I think?
Do this outside is my bet. Away from kids, Pets etc. The Can as Aluminium will stop 88%, if you've plated it in Gold then 98-99%, background radiation only or less.
Do not look down the spout? 0 Protection.
Please DO NOT respond yet, there is another section to go below this one.
Welcome and good luck.
Edit: Just noticed your continuation demand, sorry. Any moderator can delete this post of mine.
aoi3610
Here is a Picture of the Eye Of Horus, showing the fractional representation:
https://poor-brother.wikispaces.com/file/view/wadjet.fractions.png/33047917/wadjet.fractions.png
This is how I came to the materials / figures via the Periodic Table and the 2000+ year old "Eye Of Horus" fractions:
You have to note the R shape within the Eye of horus for the reactants.
Fraction Mass Size / Diameter Radius Element / Material
1 130g 130mm NA Dry Earth 1g/cm3
1/2 (R) 16g 65mm 32.5mm Lead - 10.x g/cm3 (+/- Solid / Liquid density)
1/4 (R) 4g 32.5mm 16.25mm Tin - 5.x g/cm3 x (+/- Solid / Liquid density)
1/8 (R) 2g 16.25mm NA Aluminium
1/16 (R) 0.5g 8.125mm 8.75mm Silicon 2.5g/cm3 (+/- Solid / Liquid density)
1/32 DARK wood
1/64 LIGHT wood
The Missing from 63/64
1/64 Tiny Plated NA GOLD 20g/cm3 (+/- depending on Liquid / Solid)
I did not guess.
The Light / Dark is for regulating the "device".
Do you think the above works out by chance?
I keep trying to put this simple bit over;
The can has a surface area of 150cm2, it is 300C in the oven, the surface area of the Lead is only about 1.5cm2, that is 100 times smaller. The Tin is 400 Times Smaller, the Silicon is 1600 times smaller by surface area.
300C @ 150cm2 into 0.15cm2?
Doesn't take a genius to work out it is going to be VERY hot round the SILICON.
The HEAT can only go into the centre of the can, it is coming from all direction, like a magnifying glass.
Enough time and that 300C become 3000C and more, at the centre of the can, and will continue increasing as more energy is put into the can, the hotter the Lead becomes, the hotter it want to become.
The heat travels up the can, forced into a smaller space, into the TIN, this keeps going the tin is only 4g, it's TINY, etc. on to the SILICON.
aoi3610
Quote from: broli on January 13, 2011, 07:58:07 AM
Thanks, it does not matter, your post is small.
I have produced about 5 of the above devices;
Once hot it will produce a flame for about half an hour, by which time it has cooled.
Pop it back in the heat, and away it goes again for another 30 mins or so.
When you then dis-assemble it, 4g of the Lead is GONE.
I have only used straight Aluminium, I am this time gold plating a can, which is harder than you can believe.
However, Gold has a much better reflectivity than Aluminium 88% vs 98-99%.
Gold is the Key.
By the way, there is nothing in the can to "burn" per se.
Dry Earth, Lead, Tin, Silicon and Aluminium (The can)
That is it.
The Silicon ends up as a ball of glass. (thats 2000 degrees C on it's own)
Thanks for looking.
Quote from: aoi3610 on January 13, 2011, 08:08:25 AM
If you put it back does it again have to be 4 hours long?
