Thanks to ALL for your help!!
Grounding human body during sleep.
Started by broli, January 19, 2011, 06:01:01 AM
MrMag
I think it probably would help. This is not the first place I heard about this. Walking on the ground barefoot is good for you. I have did a lot of research on George Lakohvsky and he said that the grounding was very critical, and he wasn't talking about the ground on his machine. He was very picky on where the machines were installed because of the earth ground and the north/south positioning of the antennas. He also said that we should eat local produce since it is grown in the same soil as we are used to.
screaminvern
Quote from: quarktoo on January 19, 2011, 03:52:07 PM
That is interesting but some of it could be due to placebo effect.
A similar concept is to take an insulated aluminum plate and run a wire from it to a box in your basement. Place AL foil in the top of the box and put a plant inside. Place another piece of foil below the plant and attach that to ground. The plant will grow inside the box even though no light can get in. Place a test plant in a box beside it without the foil and it will die.
This really has some merit. I ran across this idea at rexresearch.  I began a project on growing plants in the dark on Oct. 17 2010. I started a tomato from seed in a basement room that has no windows. I have a collector plate on the roof and a emitter plate above the planter, both plates are 6" by 10" and connected together with 18 awg copper wire. I have a plate inside the planter on the bottom hooked to a ground with 18 awg copper wire.
I did not have a control planted with the first experiment because of the lack of room, but after  seeing the results, I did some rearranging and I now have two planters and will be starting over with a control in the experiment. Here are some links with pictures from the first go around.
http://i805.photobucket.com/albums/yy337/screaminvern/09-24-10_150852.jpg
http://i805.photobucket.com/albums/yy337/screaminvern/09-24-10_151304.jpg
http://i805.photobucket.com/albums/yy337/screaminvern/09-25-10_193144.jpg
http://i805.photobucket.com/albums/yy337/screaminvern/10-01-10_062750.jpg
