Break through!
Started by Butch LaFonte, January 25, 2011, 01:10:58 AM
Magluvin
I agree with Butch here.  He is presenting an idea that from his mass of experience, he believes it may work.  Nothing wrong wit dat. At least he shows, and shows, and shows.  While many others show just nagging text like they rule er sumthin.
I still think getting the plates to separate will be a good trick, but he is right, its a great seed. We need to try and do anything and everything to accomplish this goal, no stone unturned.  ;]
Well now I think maybe there should be 3 sections of this forum, the Nags at the entry level, then newbies can get elected to an intermediate level that accepts any experience level nag member, and then the elite level can elect from that level to join the best.   This way everyone gets a fair chance to be part of the club. Everyone graduates to the next level by earning it.  This would keep the real thinkers to the thinkin instead of replying to bs posts.
Keep it coming Butch    Just ignore and just post the good stuff, cuz the nags feed on the replies. ;]
Mags
Butch LaFonte
Butch LaFonte
This is the correct drawing for Pure Pseudo Solid
Thanks,
Butch
mscoffman
One problem I have is that the motor rotor doesn't seem to imply
any asymmetric force vectors? Why does this want to rotate except
by some sort of magnetic phase delay? Magnetic fields can equalize
instantaneously when they want to.
:S:MarkSCoffman
Butch LaFonte
Mark,
Look at the illustration in the upper right of the magnet and rotor.
Imagine the pseudo solid slugs not on the shaft, just the narrow flat square rotor.
When it is just past 90 degrees to the magnet poles the torque would pull it vertical to line up with the flux field with a very strong force. It would probably cut your finger off if you had it in the way.
Then the pseudo solid slugs move in and make it a solid steel bar in effect so it can rotate 90 degrees to start the cycle again.
Butch
