FEMM simulation showing COP 3 and 7
Started by broli, February 01, 2011, 06:12:48 PM
I attached the sim and script. The scale is in mm, the script is set to a distance of 50mm, which you can adjust. Results are stored in the text file that is created.
Low-Q
Quote from: broli on February 14, 2011, 04:08:30 AM
This is GREAT! Thanks for your help :) :)
Vidar
Low-Q
Do you know where to modify to move a group sideways?
Here is the original script:
mydir="./"
outforcefile = mydir .. "ForceResults.txt"
open(mydir .. "Forcetest.fem")
mi_saveas(mydir .. "temp.fem") --make a temp file for the processing
-- the step size
increment = 1
-- determines the total distance to move up
distance = 50
-- calculates the amount of steps
steps = distance/increment
-- this part empties an already exsting file.
handle = openfile(outforcefile,"w")
write(handle, "")
closefile(handle)
   -- The main loop
   for n=0,steps do
      mi_clearselected()
      mi_selectgroup(1) --select the TT shape
      mi_movetranslate(0, increment) --move up
      mi_analyze()
      mi_loadsolution()
      mo_groupselectblock(1)
      forceY = mo_blockintegral(19)
      position = n
      handle = openfile(outforcefile,"a")
      write(handle, position, "\t", forceY, "\n")
      closefile(handle)
   end
        mi_clearselected()
Vidar
Depends when you want to move it. If it's after you moved the TT's up then just copy and paste the entire for loop so you have two for loops. Then adjust the content of it appropriately. I can do it quickly if you give me the needed info.
http://pastebin.com/tpB4xdSG
Low-Q
Quote from: broli on February 14, 2011, 07:42:55 AM
Basicly I want group 1 (not necesserely the TT shape) to move to the right 50mm with 1mm steps. Well, basicly the same as the "upwards" script, but I want it to move to the right - not up.
Hope this information helps - I am too rookie with scripts to ask the right questions I guess :)
Vidar
