1 kW zero point energy @ Peswiki.com
Started by Low-Q, February 10, 2011, 07:48:07 AM
neptune
@ Woopy .Thanks for the info re RPM .That , to me is very reassuring . However we have to realise that lower RPM = lower frequency =Larger values of L and C . In my mind there can be no doubt that the magnet is diametrically magnetised , because this is shown in two separate diagrams by Prof Turtur . Why would you therefore be in any doubt ? Is the magnet shown in your photograph diametrically magnetised ?I have already emailed the prof with this question and as soon as he replies I will post his answer .
          These days I can not do much in the way of a build due to health issues . I keep getting a few ideas though ,and sooner or later I might say something which will help someone .A cheap way round the magnet problem would be to embed two cubic neo magnets in a wheel cast from epoxy resin . Possible issues would be , magnets would try to escape at very high RPM . Further into development it might be possible to have multiple magnets/poles ,leading to higher frequencies at lower RPM .   I believe higher frequencies = greater output .
neptune
For anyone contemplating a build ,as we have discussed earlier , there is the problem of the coil and the shaft needing to occupy the same space . Earlier I showed how to overcome this using a short shaft . However for those who wish to use a longer shaft running through the coil here is a suggestion . Google  Bedini-Cole window motor ". I You should easily find pictures and diagrams that show the shaft arrangement , which can be adapted for the current device .
DreamThinkBuild
Hi All,
I've modified the Octave code with help from Haithar although I'm still getting strange readings. This formula is very touchy because it calculates off itself each proceeding value in a 10000row*6column matrix. One small value change creates a cascading amplified effect of any error. I've attached the latest code for those who want to try it. If you see any errors or fixes let me know.
@Neptune,
Sorry to hear of your health. Your input is greatly appreciated you never know what phrase will spark a great idea. You are right in the simulation increasing the 100rpm speed to 200 greatly increases the output.
@Laurent,
I'm pretty sure the magnet is diametric. If you place a diametric magnet on a strip of metal it should have resistance when you try to roll it from one pole to another. If it's not diametric N/S on the top/bottom it should roll with little resistance on the same strip.
neptune
@DreamThinkBuild .Thanks for the kind words .My big problem is I have gone blind in one eye ,and the other one has a cateract . But they say that in the land of the blind , the one eyed man is king,so no worries .
          I took another look at a bike dynamo today . It is years since I stripped one down . The magnet used to be a steel cylinder , but later ones are a ferrite type material , and possibly by now , neodymium . At the top of the device is a "neck" about 2inches long and a half inch in diameter .This contains the shaft and bearings . If you removed everything except the magnet , shaft and bearings you would have the basis of a small device , but the outside diameter of the coil would be limited to about 4 inches .
, or it would cover the pulley . I cant help thinking you could use thedynamo [alternator ]  just as it is and connect a suitable cap across it . These dynamos are very inexpensive[$10 ?] to buy .The big problem is to determine the resonant frequency of the resultant parallel tuned circuit .Does anyone have a circuit for a simple LC oscillator circuit without a coil tap that will work at about 100Hz?
haithar
I wrote you a personal message neptune, you can test my C++ version with easy user interface for Turturs algorithm, it's not yet ready for public but you can use it without any problems.
