1 kW zero point energy @ Peswiki.com
Started by Low-Q, February 10, 2011, 07:48:07 AM
neptune
Re bicycle dynamos . On stripping a modern bike dynamo [which I picked up on the road!] I was disappointed to find that the magnet has more than 2 poles , and so is not suitable for use in this experiment . You can test this without stripping by simply counting the cogs in the cogging effect . Oh well , back to the drawing board .
haithar
I have uploaded my software for everyone to use and try things out: http://www.overunity.com/index.php?topic=10467
neptune
I recently received an email from Prof Turtur . He answered some of my questions . He confirms the shape of the coil as a disc shape , small height large diameter . He recommends a neo magnet because of its high field strength . He says it can be as small as 8cms diameter . He has concerns however about it flying apart at the necessary speed of 50 ,000 to100,000 RPM . He talks about plastic encapsulation .He says the only way to start it is with a starter motor at 30- to 50 ,000 RPM , and suggests an overrun clutch  , so when the device starts due to correct tuning , it will accelerate . Total capacitance needs to be 10 to 100 microfarads , capable of being varied . { could be a combination of fixed and variable caps ] Cap needs to withstand 1- to2,000 volts . Hope this helps .
Super God
Quote from: neptune on March 06, 2011, 11:56:46 AM
Did he mention the inductance of the coil?
>9000
neptune
@Super God. He does not state the inductance of the coil .However , the tuned circuit needs to resonate at 30,000 RPM = 500 cycles/sec [Hz]. coil inductance depends on capacitance . I would choose a capictance near the upper limit of what he says , as this then =less inductance =less wire=less parasitic resistance =higher Q factor .Hope this helps .
