Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
raburgeson
The picture has already had equalize done to it. It is the only thing done to it. I will load it back into my computer an get you directions to the engine. I'll be back soon and update this post within 24 hrs.
Directions to the engine. It is above the third sawtooth point from the left at the bottom of the picture. I use the black edge across the bottom to navigate. Scroll up from the third black peak slowly, if you miss it, (I doubt it) , it's half way up the hill.
raburgeson
I stand corrected, this is the raw image I downloaded from the Russians. If you have read all of the posts you will already know Equalize in Photoshop gets the red out better than Visine. Use Equalize on it. Modify is missing from my choices and I can't simply edit the above message so. I use the black part of picture frame edges across the bottom to navigate by treating them as saw teeth.
The skeleton is from the bottom left 4 and 1/4 saw teeth from the bottom left and 1/3 way up from the bottom.
For those that do not have photoshop, I will equalize this and save it on photobucket also.
raburgeson
Link Equalized,
http://rapidshare.com/files/120849467/larryslookout_spirit_big2Equalized.jpg.html
Photobucket wanted to limit me to 1 meg. so I had to put it here. They might be reducing the size of the picture at the download link too, I have no idea, Rapidshare will not modify it or delete it at the request of a government.
raburgeson
Oops, wrong skeleton, try 5 and 1/2 teeth over from the left and 1/4 way up the picture.
Notice the air brushers use three colors yellow and either blue or pink, then they cover the whole base tone patch with black. Well they are suppose to they missed on the edges in a lot of places. After you identify the finish coat you can see they went back over most of the shadows to try to make the airbrushing blend in. A lot of that is real second grade work, shadows do not instantly turn black. Some air brushing can be picked out by grade school kids. See if you kids can find shadows that are fake. Light air brushed areas are simply green streaks with a couple of yellow dots and dashes sprayed on. Notice the solar panels are surgically clean, my hats off to the cleaning crew.
TheOne
You should maybe use pixel coordinates, the first one coord, i found it but its rocks i am sure.
For the second coord, i did not find anything
