Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
I have stumbled upon something with my new ultrasonic setup that I must share.. Please read:
Nuclear fusion by inertial confinement: a comprehensive treatise AND
http://www.wbabin.net/physics/fitzgerald7.pdf
It would seem that a properly configured ultrasonic setup can do a lot more then just simple Water Mist and exciting Crystals. The neat thing is that one reactor can do a broad range of functions that's accomplished by adding a Potentiometer to handle sweep.
Fun thing for you guys with a scope to try, is attaching a Microphone to the side of the reaction chamber you have built. Then put a scope on it. You can adjust the water resonance inside very accurately.
Try it out. It works!
-Altrez
Slovenia
Pierce Oscillator Circuit
March 18, 2011
Power1
You're making it harder than it is!!
Guys, you are making this harder than it is.
I had asked that you look at the Pierce oscillator circuit, the transducer is
driven only by crystal transistor with capacitor. Oscillation can be altered
by voltage, crystal angles or temperature. Wave frequency in the water needs
to be 43khz +. If you keep increasing frequency, you will end up with
abundant HHO from piezo only.
The Zno crystals amplifies the effect. What bonds H2+0, it has a property
that you are controlling here. You need to adhere ZnO to a permanent
structure. What crystal geometry best amplifies wave frequency? They are
the same ones used in electronics.
Nebulizer circuit, same as humidifier.
http://www.tdk.co.jp/tefe02/ef441_nb.pdf
Look at the Sol-tec video. There's a comment on a patent application there
from Japan, research it. There are many ways to dissociate water into HHO
with little energy expense.
You do not have much time!! TIME is a luxury which you do not have.
Earth is Changing!
Slovenia
With regard to the spark gap scenario as it would relate to this project, I remember reading in the Aaron (spark plug 2) thread where Power To Be said the "Lux" spark plug was very simple and all that was really needed.  I don't remember Power's exact words but I think he meant what I have shared.  I need to see if I can find that post again.  He wasn't allowed to many posts on that thread, so it should be easy enough to find.
The Power To Be
Thank you for the link altrez.
D20 heavy water and other types of water have different qualities, I suggest that we concentrate on regular tap water first to give you the understanding needed before you go full nuclear or worse nucleate yourself with higher energy water elements.
Current nuclear is no match for water nuclear, it is more powerful, abundant in supply  very low cost and safe. All you need is readily available, ultrasonic humidifiers already has transducer and workable circuit. The equipment needed to build robust, maintenance free Home Power 10kw water sonofusion is readily available and it is very cheap.
Schauberger developed the  Heimkraftwerk for domestic electricity production. It was taken away and buried deep, yet no one understands the true principals of fluid dynamic and no one has ever been able to replicate his machine.
http://www.implosion-ev.de/html/heimkraftwerk.html
The only way for you to understand is by doing this experiment and observing. It is my hope that you will learn to understand and respect Nature and deploy these technologies for the benefit of mankind and NOT weaponize the forces of nature to accelerated our current demise.
"Energy producers around the planet are saying in effect, “We own the energy you want but you must pay our price we set.”; and, “Any price we set is reasonable according to private sector markets our friends control.
That is why I encourage all governments to stand firm and keep rights, patents, and copyrights on sonofusion in the public sector for as long as it takes for money mad crooks in the private sector to die off. Governments in the meantime can pay off their debts with fusion and put millions back to work." - Frank B. Fitzgerald
Slovenia
Hi Power To Be,
Maybe so, but few know how to apply it.  Also, few who know things are willing to share.  You are willing to share and have shared and that makes you very special.  What you have shared will be used by many who aren't that grateful but still you share and that is good.
I studied Schauberger for quite a while but was never able to connect any usable dots so that I could utilize any of his technology.  I would really be grateful if you would show us how to make 10 Kw with water.  I'm very excited about this.
Best Regards,
Slovenia
Quote from: The Power To Be on March 20, 2011, 07:47:12 AM
Slovenia,
Thank you for your interest but really, these are old findings of others that I just have happened to stumbled upon. I am your equal, no more and no less.
