Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
The Power To Be
Something to think about:
Tesla A/C - conversion of mechanical force to electrical oscillation.
Tesla Oscillation/ Tesla Transformer - variable frequency conversion to electrical oscillation.
Piezoelectricity Crystals - conversion of DC into electrical oscillation, also variable.
Cavitation in sound wave, light wave/ laser, ultrasonic waves etc. all have the same properties.
Oscillation is natural waves,  helices. Only difference is wavelengths.
What is the link here?
How does wave propergate in musical instruments, a drum or trumphet.
"My second discovery was of a physical truth of the greatest importance. As I have searched the entire scientific records in more than a half dozen languages for a long time without finding the least anticipation, I consider myself the original discoverer of this truth, which can be expressed by the statement: There is no energy in matter other than that received from the environment." â€" Nikola Tesla
Notes on Sonofusion:
Tesla had already shown us the way, I wish not to discuss this process any further at this time until full understanding of current project is achieved.
Slovenia
Sprocket
I finally got around to dismantling my humidifier to experiment with.  It's rated at 30W max and out of the box, does a pretty good job at producing 'steam' at max setting from water. Taken apart, it is obvious that one of the biggest problems the transducer has is overcoming the waters own viscosity.  So does anyone know of a way of reducing the natural viscosity of water?
I also tried it with isoprophyl  alcohol and our old enemy gasoline.  Gasoline's reaction is really impressive - even on the lowest setting its like dropping water onto a hotplate, it's 'steam' almost immediately!  Makes me wonder why this direction for improving fuel consumption seems to be relatively unexplored, particularly since at least one patent exists that uses ultrasonics for this very purpose.
@Slovenia - where does the Zn0 fit in this design?
b_rads
Quote from: The Power To Be on March 22, 2011, 06:06:52 AM
The intent of this post is not to derail or sidetrack anyone.  I found these links and it is turning the lights on for me.  In my opinion this defines the relationship of the zinc in this process and possibly why the power requirements might be less to split the water.
http://www.greencarcongress.com/2010/03/pzec-20100316.html
Also related to this same article is the patent application:
http://www.faqs.org/patents/app/20100012479
I found this interesting in the application:
[0010]More specifically, certain piezoelectric materials, including but not limited to α-quartz (SiO2), ZnO, or BaTiO3, among others, have unique piezoelectric properties where the piezoelectricity is an intrinsic property of the material, such that no physical/chemical doping (cations or anions), chemical additives (including transition metals) or any forms of implantation are needed to create these properties. In addition, one of the materials having these properties, i.e., quartz, is also one of the most abundant minerals on the Earth's surface (i.e. beach sands). As a result, by using quartz as a material in the process, the hydrogen production via direct-water-splitting can be achieved at a low cost, and, because quartz is a natural material that is environmental friendly, no pollution issues are created by the process.
Brad S
Cherryman
@ B-rads and all
I noticed in the link provided above  that he did the experiment in a (glass) quartz tube.
QuoteDr. X took periodic readings of his instrumentation and was assured that the standing wave was being maintained. Suddenly, with no warning whatever the water disappeared from the open quartz tube. He looked up thinking to see the water splashed on the ceiling when to his amazement a clean hole went right through the ceiling. The hole was the same size as the inside of the quartz tube.
Could it be possible the quartz tube accidently had an effect on the process?
Another question:
If you grind a larger crystal, does that result in smaller crystals? Or is the structure broken when you do that?
Example: grinding quartz sand to powder, would that powder still be small crystals?
