Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
b_rads
Quote from: The Power To Be on March 22, 2011, 06:06:52 AM
Something to think about:
Tesla A/C - conversion of mechanical force to electrical oscillation.
Tesla Oscillation/ Tesla Transformer - variable frequency conversion to electrical oscillation.
Piezoelectricity Crystals - conversion of DC into electrical oscillation, also variable.
Cavitation in sound wave, light wave/ laser, ultrasonic waves etc. all have the same properties.
Oscillation is natural waves,  helices. Only difference is wavelengths.
What is the link here?
How does wave propergate in musical instruments, a drum or trumphet.
The Power to be:
I most likely know less about this than anyperson on this forum.  From my reading into this subject, I think this is what is going on here.  By exciting the water at the correct frequency (weakening the hydrogen oxygen bond) and sending the zinc crystals into a frentic dance (bending and flexing) smashes the cavitation bubbles dissassociating the water.  By amplifying the the oscillations reduces the energy required the make the zinc crystals dance.  If this is true, I am truly amazed that you uncovered this method.  Kudos to all you do.
Brad S.
RAD-HHO
Quote from: The Power To Be on March 18, 2011, 09:27:09 AM
RAD
I must say that I only use simple things from 19th century era, works just fine,  I had tuned my chamber with a balloon. If you are measuring water at 1.7mhz, then you should have lots of HHO already!.
I'm not sure how you measure the vibration frequency of the water with just a balloon, but I was able to do it with another piezo disc.  I have two slightly different piezo ultrasonic water foggers.  I measured one @ about 1.7 Mhz, and the other @ 2 Mhz.
I checked the gas mixture with an LEL gas monitor, but it did not register anything.   :(
This was without any ZnO crystals in the mix.
Super God
You need more energy to move the transducer faster. If all we need is 43khz, then we should work to lower the frequency to that level. If we had a 2mhz signal and enough energy to drive the transducer enough to separate the water then maybe...hmm.
>9000
RAD-HHO
Quote from: Super God on March 22, 2011, 02:29:29 PM
Plenty of power.  It melted a hole in the side of the rubbermaid container at the focal point when I had it on its side.  It produces plenty of fog.
http://www.youtube.com/watch?v=pYO18DyR-Jc
http://www.youtube.com/watch?v=PK01ezJlLXA
