Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
RAD-HHO
Quote from: altrez on March 23, 2011, 07:02:34 PM
As far as I know you cant do it with only a toroid. If one could that would be extramly intresting. When you apply straight DC current to a toroid you create an Electromagnet.
-Altrez
EXACTLY!  ;D
Read back a few posts.....
altrez
Quote from: RAD-HHO on March 23, 2011, 07:05:05 PM
EXACTLY!  ;D
Is this what you are talking about?
"There are many ways to controlling frequency. It depends on what you are using, I used 36 volts stepped up from 12v using  a simple toroid wound step up transformer, the same one they use in JT light. My frequency was controlled simply with a pot, rectifier, caps and a crystal transistor was only needed component."
If so that is simple. You take the 12v DC run it into a JT with a secondary use the rectifier to convert the 40 or so volts of AC output back to 36vdc. Adjust with a Potentiometer.
Make sense?
-Altrez
RAD-HHO
-Altrez
I'm sure I just misunderstood Powerme.  What is a JT light?
The Power To Be
What did Lord Kelvin said about primary winding?.
What is the Hall effect in transformer core?.
What difference does it make if you pulse with transistor or crystal?.
Build it and observe.
;D
altrez
Quote from: RAD-HHO on March 23, 2011, 07:11:58 PM
Joule Thief. Its a simple circuit that uses very few parts.
-Altrez
