Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Nrgaway
What are people using for their pure water aqueous environment for testing the ZnO crystals hho production?
In particular are they submerging the transducer directly within the water solution or putting the container above above transducer like in the way the Branson 5510-MT Ultrasonic Cleaner works ?(manual url: http://www.bransonic.com/pdf/p214-142ra.pdf).
I would think either way would work, but not having the transducer exposed to the water would likely make sure its life span is greater.  Maybe using a quartz flask / beaker would then contain the the deionized water and crystals for the test?
Slovenia
Power To Be was saying to just use plain tap water.
Quote from: Nrgaway on April 03, 2011, 05:37:32 PM
Slovenia
Recommended Circuit
(Pierce Circuit with subcomponents such as)
Frequency Control
March 23, 2011
from Power1 Post #266 @ OU
There are many ways to controlling frequency. It depends on what you are using,
I used 36 volts stepped up from 12v using  a simple toroid wound step up
transformer, the same one they use in JT light. My frequency was controlled
simply with a pot, rectifier, caps and a crystal transistor was only needed
component.
Components:
Pierce Circuit Configuration
36 volts stepped up from 12 volts using:
simple toroid wound step up transformer, the same one found in Joule Thief
light,
Pot,
Rectifier,
Caps, &
Crystal Transistor
P.S.:  Power To Be, I'm not trying to parrot or mimic you in any way.  I have great regard for you and would not maliciously say anything against you.  You have helped me a lot in many ways and I don't repay good with evil.
Favor Request of Electrical Person:  (Someone in this Group)
It would be nice if some electrical person ran down the components we need for a suitable Pierce Circuit to Power1 specs so the rest of us will have a guide to go by.  For instance, Power1 mentions caps as one of the components he used with no specifics as to the type of cap.  We need someone to lay out specific subcomponents for us so we can make a good Pierce Circuit for this project.
Please help us out here electrical guru.  Thanks in advance!!
petar113507
I need to run a few more tests on this during the following week -- but I got some basic results from this weekend.
So far, as I have been able to measure -- I could run about 40% mixture water/ 60% atomized gasoline without noticing a difference in power output -- the engine runs just the same.  This already represents a chunk of prove-able gas savings for me.  :)
The reason I need to do some more tests, is because when I get it a round 50-50%, I need to adjust the air/water ratio in th water mixture, in order to keep increase the percentage of the atomized water vs. gas.  I just need a little bit of fine tuning -- so it'll just be playing with the setup this next week.
What's nifty here, is this part of the project is the part without the crystals yet, and without the HHO addition to the atomized water.  I'm still waiting for the pizeo's to arrive this next week.  (Delayed shipment on pizeo :( ).
Thanks for more posting, and interest in the thread everyone!  I am restricting my posting to "progress only", so that I spend time working on things I need to do.  This is turning out to have good results so far.  I think those spark plugs allow it to run pretty well on the atomized gasoline/water mixtures.  Adding HHO to the mix will only improve efficencies from here on out. :)
Will post procedure of How I tested the increase/gain from the engine when I do it more in the following days.
Slovenia, thanks for archiving everything to make it more easily accessable to all.
Powerme, I will do the best I can to continue to learn.  Thank you for what you have shared already.
Goodnight all,
==Romo
Slovenia
Romo,
Thanks for sharing your update.  It's very exciting indeed.
Best Regards,
Slovenia
