Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
DreamThinkBuild
Hi All,
Could you replace the zinc crystals with atomized quartz crystals?
The Power To Be
RAD, conduct simple test with Luc’s spark circuit, record your result and continue, don’t need to be more complicated, simple is better.
Fishman, the purpose of this project is to teach folks Nature’s Truth knowledge, transmutation, element phases, elements properties etc.  etc. These things are not taught in School. Give people the proper knowledge and people will have the abilities to do ANYTHING!!, Folks, you do not have the slightest idea of your True Potential, You can be as knowledgeable as Tesla, if you choose to observe nature and listen to your own Intelligence.
Kapanadze, Ismael Aviso etc, they only found their knowledge from self learning. By continuing with the Installed System of knowledge, you are only parroting falsehood knowledge such as Einstein and Thompson, I never did subscribe to those views, jargons such as neurons is a legalese to describe Nature which is useless.
Dream think, you can use any piezoelectric crystals, quartz, transitional crystals, you just need to transmute crystals by fusion with high energy elements like ammonium, this results in higher piezoelectrochemical activity. I use ZnO because it resonates well above 40khz, the range where water freely dissociates.
Geo, yes, water will freeze at -0 C, this will yield anhydrous ammonium which requires extreme care, I suggest that everyone only use Sola Distillation to make 30% unless you have the proper facilities to store 100% freeze separated ammonium.
The Power To Be
How do you listen to yourself, to your intelligence?.
I cannot answer that, only you can.
How did you learn to walk, how did you learn to speak?.
Do blindfold tasting, blindfold walking a straight line?.
How did you do that?.
Only you can answer that, but I'll give you a hint, it only happens if you are sincere and honest. Understand tht we are all Equal, only then will you become your own Teacher.
How do you read 1000 wpm and have patience in waiting for your unconscious to catch up?, how do you do bizarre things like leaving your body, encountering other Intelligence beings?,  that is bazaar things that I experience but wish to leave out of discussions.
Super God
Quote from: The Power To Be on March 01, 2011, 12:52:26 PM
Makes sense, you are a spirit with a body.
I'm ordering stuff for this project, too. I already have the plasma discharge circuit setup correctly, I'm sure that will cause results even without the crystals.
>9000
The Power To Be
Thank you Super God, you are the Spirit, allow you're spirit to grow and mature, then you will be able to do anything.
You're current state of mentality is no difference from a caged Lion, in Nature you have freedom and posses extra sensory, but confined in a cage, you then become same as all other domesticated pets.
The knowledge you posses is like telling a Bee to ONLY make honey from citrus, and after many generations, you only know how to make citrus honey, Imagine the possibilities if you wandered off and tasted pollen of other trees!.
Do not believe what others are saying, Do not believe me either!, Only Believe yourself, that is how you learn. From observing your own work.
Do not subscribe to organizations, religions  etc, they will only hinder your development, ofcourse they are good for socializing but only apply Facts if they make sense to you first.
