Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
fishman
Quote from: petar113507 on February 28, 2011, 09:19:28 PM
The next questions I have for the future:
1)Has anyone found any retailers for the sub-micron-pore bags?
On Powerme suggestion.
I did tare apart a small lawnmower battery today. 24 PEM envelopes where inside 5" x 4".
Water does not seem to flow through them at all.
Super God
One thing I am confused on is, if the crystals are not wet, how will they make HHO? I am totally new to this crystal stuff, but it seems to have promise.
Do we dump the crystals in the water so they pick up the waves? Can the crystals make HHO from inside the bag, even if they aren't touching water? I will experiment once I get the necessary equipment.
I know my (capacitor70's) circuit causes water to react anomalously and "explode" in the cylinder when subjected to high current, but I do not know why. Perhaps it is doing the same thing the crystals do.
>9000
The Power To Be
Hey Super God,
Do know that we are al Equal
My envelope was my method of measuring piezoelectrochemical effeciencies of several different types of crystals in a controlled manner effectively.
Forget about the envelope, just put your crystals in the water and conduct your test, the crystal needs to make contact with the waves, envelope blocks most of the waves. You need to permanently adhere crystals to a surface, you decide what you think is best. Porous composite, electro plating, aerated ceramic, etc.
Where we are heading is the Forbidden Zones of knowledge, and You will get LOST is you continue with your current understanding.
The ZnO refluxed with NH3 under pressure forces NH3 to bind with ZnO at molecular level, same principle employed at Gene Modification where atom size particles of other elements are bombarded into living cell.
What causes these transmutation?.
What are the electrical properties of these elements?.
What are their electrochemical properties?.
What causes piezo electrical conversion of acoustic waves?.
What is a wave, why is it not called a helix, there are 2 equalized intertwined forces isn't there?.
Why do elements known transmute or transform into other known elements, what is the cause?.
There are other many fascinating things that you will learn, phase changes that occurs, what causes them, how to control them etc.
You are the Teacher, you are the Creator, there are many powerful things that I wish never to disclose as you first need to understand Nature and the Responsibilities that lays behind these Wisdom.
I can control the forces of nature and so can you!.
Super God
Quote from: The Power To Be on March 01, 2011, 05:13:02 PM
Hey Super God,
Do you subscribe to the Pantheistic theory, in that we all as a whole compose everything? I don't know about that (I am Spiritist) but I do know that this information is for the benefit of Humanity as a whole.
I do realize we are equals. Thank you for your advice, I will try to adhere them to one of the surfaces in the container. As far as lost, I'm already dazed and confused, but I will try and see if I can understand what is going on.
Thanks again for the base information!
>9000
The Power To Be
Quote from: Super God on March 01, 2011, 06:40:07 PM
I am not aware of this Theory, generally I would just listen to what one will have to say and absorb only what makes sense to me. However the God concept does help those that are starting out, but one must know that such Universal Ruler and Law does not exist, there are other intelligence entities but we are all equal.
Everything is just ONE, there is no seperation, what you experience is your own manifested delusion.
For those new to this thread, I sometime respond to question from Energetic Forum and quote them here as I no longer am allowed to post there due to their private and regulated laws and beliefs.
I have already covered the safety concerns regarding NH3, maintain reflux temperature at 60 C by cooling and excessive pressure will not accumulate. Just use the largest Mason Jar that you can find, 1/2 gallon with moist towel wrapped on top portion constantly sprayed with water to remove excess heat.
You are free to do whatever that you wish to build, there is no particular method here, just like building an automobile, all styles allowed and all will be drivable.
