Simple voltage regulator oscillator
Started by jonnydavro, February 17, 2011, 03:39:56 PM
Magluvin
Here is a data sheet on Jonny's regulator IC
Mags
Magluvin
Here is the internals of the IC    It has a cap as I suspected in order for Jonny to get the 2v out . ;]
Very interesting data on this IC   maybe the 3v vs the 3.3v may show better effects.  Jon  Was the 5v any diff from the 3.3v in quality of output as you have shown? Any diff?
Thanks for showing.  Your finds are always a pleasure to experience. ;]
Mags
jonnydavro
@Magluvin.Hi.Thanks for posting the internal schematic.I was wondering what was inside this IC as my pc won't open pdf files for some unknown reason :'(
Interesting,the internal capasitor looks like it forms a tank circuit with my coil across the output.
The 2V output is not the output of the VREG but from the rectified output of the secondary winding on the 1:1 bifilar with the negative rail connected to the negative output like I show in the 2nd circuit diagram in my first post.Without this negative connection,the rectified output is nowhere near as high.
The output from the voltage regulator if used normally using a AA battery at 1.47v is 1.43v.To get the specified output of 3.3v you have to use an input voltage greater than 3.3v.
The 5v regulator works very similar to the 3.3v but runs at a different frequency as when directly swapped the audio from the speaker changes.The 3.3v reg will light a led and charge a cap on 20uA from a 1" solar cell from ambient light and so will the 5v but the led seems brighter with the 3.3v so that is my prefered choice of the two for low voltage operation but these 2 are the only regulators I have tried so i am looking forward to trying a few different ones to see how they compare.Cheers.Jonny
Magluvin
Hey Jonny
Ill do some screen shots of the pdf this evening and post the specs as jpeg pics, as others may have the same issue.   ;)
Mags
bsibille
Am I losing my mind?? What happened to all of the Lidmotor posts this topic?
