Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
hartiberlin
hi All,
great results.
If you have problems with reed relays burning up,
try to put 2 or more in SERIES.
This way more  switches open and this will give a faster dI/dt
current change and thus also higher induction voltages and will
distribute the spark across multiple reed relays, so the sparking
on one reed relay might be reduced.
Good luck.
P.S. Why are you all just trying to do it at the sine peak ?
You can just chop the current all the time, this will give much
more spikes and does not need any synchronisation.
Regards, Stefan.
romerouk
Quote from: hartiberlin on March 06, 2011, 07:14:53 PM
hi All,
great results.
Good luck.
Regards, Stefan.
Personally I do the shorting at the sine peak just because I can get the maximum power, but you are right, I have tested with 3 reed switches positioned differently and I do get more spikes.
The reed switching is good enough for testing only but for a long lasting device must use solid state components.
I have also tried to short the wave all the way,multiple times, positive and negative using a 555  driver and i've got nice results.
I am working on a different setup too where one coil(few turns) is shorting the main coil and I get power from it plus extra flux to accelerate the rotor. Syncronising the 2 coils is a very important factor.
I will talk about this ideea once I finish the other things on my list.
I am close to have it running just with a capacitor, time is the only problem I have... but soon
bolt
Quote from: romerouk on March 06, 2011, 05:10:58 PM
This is how the sinewave looks with reed and 0.47uf for the shorting.
I have more coils now and still the system remains not affected even if I leave all coils shorted.
The system charges the running battery but still not good enough to run from a capacitor.
I can get the system to accelerate when shorting the coils too.The arrangement of the coils arround the rotor is very important too.
Now I collect the power from all coils in a capacitor and dump it back to the battery once for every revolution.
Another small discovery is that if I use a 240/12v transformer and collect the power from the MOT fan coils to the 240v side and use the 12 volt side with a rectifier  to charge the battery it charges better than damping higher voltage and low amperage.
You are a long way from looping yet and i doubt you can do this with a simple set up. If you read my posts I have been involved with this coil shorting now for quite some time and understand many of the pitfalls and how to vastly improve system gains.
When dumping load caps do not allow them to drop below 61.8% of charge capacity. This is a Fibonacci ratio and very important in nature and electronics. You will find from 61.8% to 100% will charge recover a lot quicker.
You use of reverse transformer is for impedance matching. When you get into this in more detail you MUST treat everything with the eyes of an RF engineer. Series caps provides some degree of high pass filter but usually requires Pi Tank matching and tuning into a load for max power transfer. The 0.47uF cap will also need to be tuned into different coil setups.  The aim here is to increase JUST large enough to start seeing some lugging then back off to a smaller size then match everything else after this into the load.
When you know the value of your dump cap in uF or Farads you can calculate a start voltage and end voltage versus time scoped and calculate the joules you have recovered in your dump cap. Its the best way of finding out if you circuit is heading towards OU long before you think about looping.
BTW soon when you start adding larger coils the Radiant Energy will create fuse your reeds shut so then you will have to use the 2 fets shorting circuit.
bolt
Quote from: romerouk on March 06, 2011, 05:48:47 PM
When I position the coil I always have it shorted then move it to the position where looks that the system is not affected at all.The reed position is adjusted after the coil is in place and watching the oscope to get the short closer to the wave peak.
Having 2 reed switches close to each other will give more shorts resulting more power.
I will post another video soon but now testing all different ideeas it looks like a mess and is difficult to explain what is there.
I am also trying with different type of coil, thicker wire, but for that the reed is not good enough, the spark produced is too much and damages the reed in few seconds.
The solid state circuit to do the  shorting recomended by Doug is not working properly now.I have tried all circuits found and presented here.
Just having the circuit connected without having the hall closer to the rotor will increase the power creating something like a parallel sine wave but not spikes as the reed does.
Trying a solid state AC relay with only the 240v side connected will increase the power but no spikes.
The voltage jumps from arround 40v without anything connected to the coil, just the meter, it goes to arround 72v just by connecting the 240v terminals from the SS Relay.
Loking at the oscope I can see that when adding the SS Relay I get a parallel sinewave, this is strange for me at this moment.
This is the effect I was talking about in a previous post, PARALLEL SINE WAVE.
As per my posts please read them as i know your problems and it will save you DAYS or  MONTHS of heart ache! As explained already i knew you was going to reach a point where your reed switches fuse together. Radiant Energy is very destructive in this form and you notice a very strange looking arc and color!
IMPORTANT you can not use SS AC relays they are basically triacs and only switch on and off at zero point crossing. You need DC solid state BUT most  are slow and have snubbers which slow down gate speed as usually switching within 5mS is not normally a requirement for DC loads.
Multiple shorting at sine wave peaks adds more power. Do this 5 times or 20 or even 100 times on top of the sine then you will see a MASSIVE amount of highly disruptive power its very hard to control. For this to work properly you must use fast inverter switch IGBT's driven by an AVR is best with each shorting spike down to uS's.
bolt
Quote from: woopy on March 06, 2011, 05:13:11 PM
Hi Bolt
I am ready for take off ,simply send me the soft or proposal and we go
Thank's
Hi guyla
i am trying all the stuff i have , and has i sayd all works but at different ENERGY INPUT  PRICE . But what disturb me is that DOUG sayd that with the HIGH BYPASS AC cap it should decrease the LENZ effect what i can not detect at this point of my research. Any idea ?
Good night
Laurent
There is no problem having a very slight lugging so it is just perceptible to each coil. This makes sure you are collecting as much power as possible from the coil shorts where the high pass filter is just starting to edge the bandwidth down into the carrier frequency.  Collectively you may have a 10 coil generator each collecting 50 watts each. Now you have 500 watts from the coils. The total i/p maybe 100 watts so you have a 400 watt OU device. COP 4 is typical of these systems and indeed I understand that Kone can now build them at COP 8 and higher when you tweak everything to a fine art.
I personally don't really like mechanical generators. EVERYTHING you learn here about shorting coils can apply to solid state and yes its VERY close to Magnacoaster!
If you can program then you already know what is required here to short the sine wave peaks. I don't have any code to give. Use a hard interrupt as wave sampler. Either use a PD or opto as a sine sniffer and set a delay timer to put you on top of the sine or JUST BTDC then send pulses out on pin 5 or whatever to the shorting pair fets. That's it in a nutshell.
