Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
giantkiller
I use both types of wire. Magnet wire gives great field with low current.
I use 26awg stranded silver coated copper with teflon coating for driver coils.
Feynman
I_ron, your results very much reminds me of NAudin 2Sgen / Groundloop Solid-State Orbo.
In both cases, the strong impulse occurs on the REMOVAL of the electromagnetic (electronically energized) field -- in the presence of a magnet -- which has partially saturated the toroid/core/whatever.   There's a lot in common here.
Naudin 2SGen Solid State Generator
http://jnaudin.free.fr/2SGen/indexen.htm
@GK
Thanks for the input.  I'm going to stick with solid-core wires instead of stranded (because i don't want any 'bumps' in the field), but I will definitely use magnet wire for my tests.
Feynman
Also, can someone please explain to me which diodes are backwards (if any) in the Magnacoaster patent...
Magnacoaster Patent
http://www.free-energy-info.co.uk/PatD38.pdf
Thanks,
Feynman
Magluvin
Magnacoasters diode config does seem a bit odd
I see the input diodes look as to conduct source to coil ok. But why the single diodes and bridge when the input is dc?
On the right, the bridge seems to be not correct. And if diodes 102 and 104 are correct in polarity, for what ever reason, then just rotate the bridge counter clockwise 1/4 turn and the coil will conduct to the output batt
The output bridge is looking to be accepting dc in and ac out as is.
It seems as though you could eliminate the bridges all together.
The way the output is configured, and the bridge rotated correctly, only 2 of the diodes in the bridge seem to be in use at any time.
Unless the original circuit is using the diodes breakdown voltages as a spark gap of sorts.  ;]   It is very strange, the way they have most of the diodes. Why on the input and why on the output.
Mags
giantkiller
My first thought was:
Work the bridges in reverse and the batteries get charge pumped.
But then did he have to show a working model to get the patent? I seem to recall a conversation where he did not. Therefore he could print anything or a reasonable facsimile of a working unit.
