Shorting coil gives back more power
Started by romerouk, February 18, 2011, 09:51:45 PM
hartiberlin
with R he probably means graetz bridge rectifier and the + and - output
are the DC outputs of the bridge rectifier.
Now it gets clearer.
He also uses greatz bridge rectifiers in his video.
Regards, Stefan.
Michaelpier
Quote from: forest on February 21, 2011, 05:28:29 PM
What is R on schematic ?
Does not really needed,just put an oil capacitor AC there and it should be much better.
The circuit on the videos is little different from this one.Only common is the theory.Here it is.
woopy
 hi Stephan
Thank's for your shematic
I made a crude replication tonight with the air core coil of the primary of a mot and a 12 volts relay "modified to self trigering)
The frequencys is arround 400 hz (at 9 volts input ) and i get some results but so far not extraordinary..
But i will try deeper in the  concept tomorrow
Anyway thanks for the input
And good luck at all
laurent
Michaelpier
By the way i am trying a new setup now with no moving relays and mechanical stuff.Hope to finish it soon. :)
Thaelin
    Just a tidbit here. With the magnets positioned the way they
are, when they go by the coils it will do a hard pole reversal. This
will create a sine wave output as if you had spaced north/south
magnets. You will not get as strong a field to the coils that way
but switching poles.
thay
