Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
0 Members and 288 Guests are viewing this topic.
poynt99
Quote from: Rosemary Ainslie on May 08, 2011, 10:32:40 AM
lol.  Poynty Pointy - Pay attention now.  COP stands for CO EFFICIENT OF PERFORMANCE .  The EFFICIENT part of that relates to the measured 'EFFICIENCY' of power as it relates to the transfer of energy.  It is usually compared to '1'.
Now.  You are welcome to bore us all to tears by referencing any amount of links that may have various and more LEARNED ways of describing all this.  But we only need to understand the term.  And I think we do.  Certainly I do.  lol.
As ever,
Rosie Posie
;D
You 'caunt' be serious Rose?
Do you know what a "coefficient" is?
http://www.mathwizz.com/algebra/help/help4.htm
It has absolutely nothing to do with the concept of "efficiency". Obviously you either didn't read the documents, or you didn't understand them, as obviously you still don't get it.
::) Good grief!
.99
poynt99
And btw Poynty.  I see your endless requirements for solid state configs.  Just take a good look at Groundloops circuit here.  I've got a sneaking suspicion we've already got the solid state version.  Just not sure I should reference it.
And btw Rosie-posie, I see your endless attempts to ride the coat tails of others.
Your oscillator is in no way related to Romero's device, and therefore not a solid-state version of it.
.99
Rosemary Ainslie
Quote from: poynt99 on May 08, 2011, 10:43:34 AM
::) Good grief!
.99
;D  lol.  I'll manage somehow.  And sit tight there Poynty.  We've got some waveforms to download.  You need to see this.
Rosemary Ainslie
Quote from: poynt99 on May 08, 2011, 11:08:05 AM
.99
lol. Indeed I am Poynty.  I'm hanging on there.  Much required.
;D ;D ;D
vonwolf
::) Good grief!
.99
  There old poynted boy goes cherry picking definitions and claiming  his superiority. English is a though language one word can have many definitions, um lets see, wikipedia might look at coefficient a little more comprehensively.....http://en.wikipedia.org/wiki/Coefficient
  Examples of physical coefficients
1.Coefficient of Thermal Expansion (thermodynamics) (dimensionless) - Relates the change in temperature to the change in a material's dimensions.
2.Partition Coefficient (KD) (chemistry) - The ratio of concentrations of a compound in two phases of a mixture of two immiscible solvents at equilibrium.
3.Hall coefficient (electrical physics) - Relates a magnetic field applied to an element to the voltage created, the amount of current and the element thickness. It is a characteristic of the material from which the conductor is made.
4.Lift coefficient (CL or CZ) (Aerodynamics) (dimensionless) - Relates the lift generated by an airfoil with the dynamic pressure of the fluid flow around the airfoil, and the planform area of the airfoil.
5.Ballistic coefficient (BC) (Aerodynamics) (units of kg/m2) - A measure of a body's ability to overcome air resistance in flight. BC is a function of mass, diameter, and drag coefficient.
6.Transmission Coefficient (quantum mechanics) (dimensionless) - Represents the probability flux of a transmitted wave relative to that of an incident wave. It is often used to describe the probability of a particle tunnelling through a barrier.
7.Damping Factor a.k.a. viscous damping coefficient (Physical Engineering) (units of newton-seconds per meter) - relates a damping force with the velocity of the object whose motion is being
  Good Geief indeed!
  Pete
Edit;
  Had to clean up my c&p
