Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
fuzzytomcat
That's so odd that someone would post something "FALSE" and "INACCURATE" that has nothing to do with this thread at all concerning the term "coefficient" other that to confuse members and guests being off topic and try to derail the thread.
http://en.wikipedia.org/wiki/Coefficient
Examples of physical coefficients
   1. Coefficient of Thermal Expansion (thermodynamics) (dimensionless) - Relates the change in temperature to the change in a material's dimensions.
   2. Partition Coefficient (KD) (chemistry) - The ratio of concentrations of a compound in two phases of a mixture of two immiscible solvents at equilibrium.
   3. Hall coefficient (electrical physics) - Relates a magnetic field applied to an element to the voltage created, the amount of current and the element thickness. It is a characteristic of the material from which the conductor is made.
   4. Lift coefficient (CL or CZ) (Aerodynamics) (dimensionless) - Relates the lift generated by an airfoil with the dynamic pressure of the fluid flow around the airfoil, and the planform area of the airfoil.
   5. Ballistic coefficient (BC) (Aerodynamics) (units of kg/m2) - A measure of a body's ability to overcome air resistance in flight. BC is a function of mass, diameter, and drag coefficient.
   6. Transmission Coefficient (quantum mechanics) (dimensionless) - Represents the probability flux of a transmitted wave relative to that of an incident wave. It is often used to describe the probability of a particle tunnelling through a barrier.
   7. Damping Factor a.k.a. viscous damping coefficient (Physical Engineering) (units of newton-seconds per meter) - relates a damping force with the velocity of the object whose motion is being
Again I find no useful information concerning this at all and has no bearing what so ever here on the results on calculations of the claimed COP > INFINITY other than a diversion of facts.
Fuzzy
vonwolf
Quote from: fuzzytomcat on May 08, 2011, 01:46:46 PM
Fuzzy
   Out of context but a much better job at copy & past than mine.
   Thanks
WilbyInebriated
Fuzzy
still here with your vendetta fuzzy? don't you know there's a new claim (pilgrim) in town son?? why don't you run on over there like the rest of the merry gang did. you guys remind me of jack palance in the movie shane...
the merry gang: "did you say overunity or cop > 1? pick up the gun, pilgrim..."
one of the unwashed masses: "mister i'm just here trying to do something for the planet..."
the merry gang: "pick up the gun!"
grow up son, and please pass that bit of advice on to the rest of your obsessed gang... ::)
powercat
Come on Fuzzytomcat it's great over their, the inventor of the device answers all the questions, and you don't need to worry about measurements it is a self-runner  ;D ;D ;D
fuzzytomcat
Quote from: WilbyInebriated on May 08, 2011, 02:15:41 PM
It's good to know that you are in 100% agreement with what documented testing and evaluation of Rosemary's claims of COP > INFINITY you are the first on record to be in agreement with her findings.
I personally have not found yet a complete package here or anywhere of this device, a circuit diagram, parts list, settings of the oscilloscope plus continued data dumps over a specific time frame and the function generator including what the DC offset setting adjustment was set at .... to make a verified scientific replication.
Exactly what have you found in your testing and evaluation of this device on what ever construction data your working from for a verified scientific replication?
This to me appears a "FALSE" and "INACCURATE" claim of COP > INFINITY with nothing at all verifiable to back up the claim or claims from the inventor.
Fuzzy
