Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
Rosemary Ainslie
Quote from: powercat on March 30, 2011, 10:42:46 AM
Wow Rosie
that was some statement.You now need to be a tuning magician to make what appears to be a simple circuit work, on top of being a mathematical genius to measure it properly,  Wow.
Now it makes sense why you have been on so many forums and so many threads for the last two years or so.
This really needs to be made simple (solid-state)I guess you've been relying on others to come up whit this solution, I can't blame you for that.
I think your problems will remain until things are simpler and your work can be replicate precisely by more people easier.
Cat.  You don't need to be a mathematical genius to apply integrated power analysis.  That's absolutely standard.  And you certainly don't need to be a genius to implement battery controls and draw down tests.  Nor do you need to be a genius to recognise parasitic oscillations.  It's to deliberately generate them that is atypical and not within standard knowledge.  Just remember that paarastic oscillations have actually never been studied.  They've been 'snuffed' and - according to those links - there's a whole industry invested in the knowledge of how to get rid of them.  What we're doing now is trying to get them to come and do their thing.  That's different.
But the fact is that this resonating condition is required and we are certainly breaking new ground with this.  So.  We don't have all the answers.  But I'm sure it's a short learning curve.  And remember that we did - indeed - get a full on replication posted on this and on Energetic forum.  It was not for want of evidence for that claim that there was resistance.  I thought you knew this?  You seemed to have followed this history rather closely.
Anyway.  I'm doing my best here Cat.  I only want to see this technology progressed.  But perhaps I've taken it as far as I can and should let you guys just do your thing.
Kindest regards,
Rosemary
powercat
Quote from: Rosemary Ainslie on March 30, 2011, 10:59:50 AM
Kindest regards,
Rosemary
from what I can remember of the successful replication (not enough of them)and a huge amount of arguments about the measurements
so at the moment it all as clear as mud to me
but I live in hope and wish you all the best
http://www.youtube.com/results?search_type=videos&search_query=Rosemary+Ainslie+circuit&search_sort=video_date_uploaded&suggested_categories=28&uni=3
Sprocket
Quote"Whatever ideas are the most suppressed
are most likely to be the closest to the truth."
- Weidner's First Law of the Universe
"If a picture is worth a thousand words
then a symbol is worth a thousand pictures."
- Weidner's Second Law of the Universe
"The only people who call conspiracies
' theories' are the conspirators."
- Weidner's Third Law of the Universe
@Rosemary - I couldn't resist a Copy&Paste of Weidner's Three Laws - any conspiracy aficionado will know who he is!  The first and last pretty well describe the situation.  My first real taste of this here involved Archer Quinn, I personally remember checking stats on several of the most prolific posters then - several had user-names that had been registered years in advance, but had never posted! One in particular was then posting an average of 17 post per day, many huge in size!  All to crawl back into whatever holes they had been summoned from when the melee eventually died down!  I'm surprised I can remember this many details!  OUR is kinda bizarre, the format there tends to be, Grumpy suggests something, then everyone else tells him why it's impossible!  Apparently there's no interest in what's possible, only what's impossible - a kind of intellectual masturbation methinks.  But back on topic...
Regarding tuning, I was just yesterday trying to track-down some multi-turn pots to help in this regard.  The only one I could find was a 10K 5-turn pot, but that seemed a bit high for this.  Of course there are lots of trimmers available but I'd like to get a potentiometer for this.  First time round I was just using ordinary 3/4 turn ones.  I presume with all your fancy equipment, you were just adjusting the signals amplitude and offset?  My input was fixed.
hartiberlin
I think,
as long as the function generator is still used these
measurement problems persist and the circuit is not very useable.
So better all replicators try it with the 9 Volt battery first
and try to get it running in this oscillation mode
without any function generator.
And please use low or almost zero inductance shunts, if you measure
the current as what Hummbugger has posted is true, that the
inductance of the shunts can mess up your scope shots.
Also use only Lead Acid batteries or maybe still NiMH
batteries with it, cause only these can stand the recharge pulses.
Don´t use Lithium accumulators, as they are easily blown
and can explode and cause severe fires from the BackEMF pulses !
Also you need to measure what power your load resistor is putting out
best calorimetrically heating water for example and then compare it to the
Watthours ( amphours x voltage)  your batteries are holding.
If you can run it longer than the stored Watthours of your batteries
the circuit goes overunity.
Good luck.
Regards, Stefan.
Goat
Quote from: hartiberlin on March 30, 2011, 07:40:15 PM
I think,
Good luck.
Regards, Stefan.
Hi hartiberlin/Stefan
Because of your post at http://www.overunity.com/index.php?topic=9878.msg279916#msg279916 and the connection to this thread and you're above post wouldn't it make sense to use the ceramic Y5V
caps to absorb the heat from Rosemary's heater in the circuit to further exploit the circuit into a higher COP or a feedback to a large capacitor on the I/P (input) and remove the battery for a closed loop?
I don't know but this smells of Synchronicity!!!
Regards,
Paul
