Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
markdansie
so have you had any thoughts how you can close loop this and provide any usable energy?
PS why not use Caps rather than Batteries
Mark
infringer
Mark,
Would this not make a super efficient water heater ?
Welding or soldering electronics ?
How about very cheap electric heat that could run off of stored solar power?
I could go on but this does need more looking into from a COE standpoint if this works even remotely close to what is proposed to it could mean a lot for the world.
Is free energy the only objective "Overunity" well while the name says that I tend to think a little outside of the box I'll tell you if you could do things at a lesser and lesser cost it makes renewable energy more likely to be exploited and used which in turn decreases the grip of big oil, and makes everyone's life easier until that pie in the sky of OU is discovered.
These are all stepping stones .... Hell why not try it you may like the results.
I would try it myself if I had every component on hand or knew some more specifics but I see a lot of uses for a closed loop if it works as proposed or even close to it.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Rosemary Ainslie
Hello Mark - and Infringer.  It is a closed loop - already.  But infringer, you're spot on.  I see a single solar panel as desirable as it would supply a stored energy that could trickle charge to the batteries.  I think that a high voltage source also needs to be stable at a given value notwithstanding the roller coaster voltage values when it gets into oscillation mode.  We tested this on batteries with huge capacities.  And it would be nice to know that we could use something a little more modest.  I've not tried this on anything other than the batteries disclosed in the report.
Now.  The next point - which may - I hope - bend your minds.  I referenced this simple fact.  During the period when the gate signal is negative - is the time that we induce this crazy oscillation.  This much is evident.  The current path is first anticlockwise - indicating that it comes from the circuit to the supply source.  Then.  The current path reverses and goes from the battery to the the circuit.  How is it that there is no resitriction to the flow of this current from the battery?  I have not heard anyone ask this.  The assumption is made that the flow from the supply can only happen when the gate is positive.  Surely?  What I'm hoping is that those that are more insightful here - will see what I'm referencing.  Current may, indeed, have properties of charge.
I'll try this again.  The applied signal at the gate is positive.  It allows a kind of bridge to the applied voltage from the battery supply that the current can flow from the supply - through the circuit and back to the negative terminal.  We all know that.  Now we apply a negative signal at the same point.  And this still allows the unrestricted flow of current from the battery supply through the circuit.  Not only that but the flow of that current is really strong.  That's the point - I think - where this circuit gets interesting.  To my way of seeing this - if the current from the battery supply has a distinctly 'positive' charge - evidenced in a clockwise directional flow - then there is, self-evidently - nothing at the gate to prevent its flow when the gate signal reverses to negative.  And this is the point where I suspect there may yet be some consessions to the concept of current having two distinct charge potentials.  If so.  Then - with apologies for all these 'ifs' - if current flow comprises electrons - then it could NEVER 'swap' directions and charges as an electron is a monopole.  An electron would either be repelled or attracted at the 'gate'.  Here we have a condition where the charge is not restricted - at all.  On the contrary.  Therefore is there the proposal that this may be proof that our current - whatever else it is - is NOT the flow of electrons.  Wrap your minds around this possibility and I assure you that you'll then need to talk 'unkown energy supply sources' or 'aether energy' or dark energy.  I do hope you'll see the point here.
You guys have been looking for the 'secret' to all that abundant energies.  I think on a deep but subliminal level we all know it's out there.  Compulsively interesting.  But ever elusive.  But I also think that you expect it to announce itself with some kind of definitive 'tan tan tara'.  I'm reasonably satisfied that it has never been considered as the properties of that well known electromagnetic interaction.  All have presumed that this is based on the flow or movement of electrons.  Never proven - but always assumed.  What is here suggested is that it's in the actual material of charge which has NOTHING to do with the atoms.  It's a force field that operates outside the atom.  And - if this is so, then all we need to do is use all that current potential way more efficiently.  And the best way to do this is to let that current 'just do it's thing'.
So.  It's rather prosaic in its fundamentals.  Just the well known electromagnetic interaction.  Yet it's strangely and entirely different - in its actual fundamental constructs.  That, I hope, is what this oscillation proves.  Please note, Infringer.  That crazy oscillation only needs some small inductive value on the circuit materials - and a continually applied negative charge at the gate - and the indications are that we have - dare I say it - PERPETUAL current flow.  That thing that is only, under known circumstances, enabled in REALLY cold conditions.  And what's really interesting - is that this puts paid to the idea that current flow will COST anything at all.
Kindest regards,
Rosemary
Rosemary Ainslie
Quote from: markdansie on March 15, 2011, 05:35:13 PM
Mark
Mark - we have a booster converter type thing going on where the applied voltage can be greatly reduced to get precisely as much energy as is required.  We can cook the resistor at just about any value.  And the cost of this is zero loss of charge from the battery supply.  Are you serious?  Surely this is usable?
Rosemary
TheCell
Hello
JR Hempel made an attempt to measure current in 2 ways:
1) Amps measured with clamp meter
2) Amps measured hot-wire ammeter
(http://www.practicalphysics.org/go/Experiment_698.html)
with 1) you measure both cold and normal current flow
with 2) you measure only current flow (this flow that causes heat)
Adjust them both to show the same value when applied to a normal power supply.
IMHO 2) measures RMS , if so ,choose a clamp meter that also does.
If there are differences between the 2 measuring methods you are dealing with cold current.
