Rosemary Ainslie circuit demonstration on Saturday March 12th 2011
Started by hartiberlin, February 20, 2011, 06:14:05 PM
Rosemary Ainslie
Quote from: WilbyInebriated on April 25, 2011, 12:29:44 AM
a field programmable gate array. the logic elements that constitute its most elementary workings can be changed at will by reprogramming the bits in the chip’s memory, known as configuration bits. gates, for example, can be changed to and gates or not gates, input wires can be reprogrammed to be output wires, and so on.
edit: look at the config bits as a genetic algorithm chromosome and we can 'evolve' circuits. circuits that do some amazing things.
Ok.  So is the idea here to apply a variety of settings at the gate?  Is that it?  Please Wilby.  There are those of us who read here who are mere mortals.  Please explain your thinking more simply.  If this is going where I think it is then this could be very interesting.  But right now I'm just guessing at what you're pointing at.
Kindest regards - and SO NICE TO SEE YOU'RE  PREPARED TO ENGAGE HERE.
;D
Rosie
Rosemary Ainslie
Quote from: poynt99 on April 24, 2011, 06:05:51 PM
As I said Rose, I thought that an indication of current flow back to the battery in a simulation would be of interested to you. This IS what I have shown. Are you interested?
If so, where do we go from here?
.99
And Poynty - to answer your question here.  We would all be fools to ignore the talents that are available on this forum.  But by the same token I'm seriously concerned that it first took all those posts to answer your rather facile rejections of this claim and it's import.  I can't help but ask myself why?  Why all that need?
If I am to trust you - then can I impose on you to do some retrospective and much needed moderation on your forum.  I believe that more than one of your contributors have indulged in an excess of criticism that does my name no good at all - and by association - this technology an equal amount of harm.
Come on Poynty Point.  By rights I shouldn't even answer your posts.  I've been excessively tolerant.  And only because I rather like the way your mind works.  But you've had us dancing there Poynty.  Now you need to become proactive.  And for that I really don't want to spend forever trying to work out what if what you've disclosed is also actually all that you've seen.  That surely is the deal - if we're to move forward at all.
Kindest regards,
Rosemary
ADDED
If that's not clear.  Let me put it better.  I don't trust you.  But I would prefer to as I'm happy that you'd bring some real value to the table.
Rosemary Ainslie
And MileHigh - I really don't want to encourage you by answering any of your absurdities - but let me remind you.  You and your predictions are as relevant to this discussion as the Jurassic period of the Mesozoic era.  They're already outmoded - even within classical paradigms.  You've just never caught up.
Just remember that the survivors of that era had to 'FLY'.  You're still crawling along - bound as you are by all that antiquated thinking.  But I'm glad that you're happy with it.  I realise that you're rather monstrously hide bound - being as it is that you belong - not to this century but to the centuries past.  Would that we could all live there.  It was a far less polluted and a far less populated place.  But reality bites MileHigh.  And right now you're doing what ostriches do best when they don't want to see what's coming for them.
You most CERTAINLY were enlisted.  The whole point of Poynty's forum is to entrench paradigms that have already collapsed all over the place - LONG back.  All those members are enlisted.  What you represent is the wate product of this new age reach into new thinking.  You are absolutely not capable of it.  But nor can I blame you.  We all have our limitations.  And if I'm a carricature - it's a carricature that I'm really happy with.  You're own is easy.  Just need to picture a tyrranosaurus rex that has also lost those teeth.  Sort of loses it's scare factor - it's local or general relevance.  And it certainly then also loses any kind of interest - except of course - for other elderly dinosaurs.  I just wish you'd stop trying to make a meal out of discussing me.  It's exhausting.
Rosemary
Rosemary Ainslie
And anyway - on a more constructive note.  Guys.  We've got a new Tektronix functions generator.  I believe it can give a 5% duty cycle.  We'll be trying this out today and hopefully I'll have some measurements later.
Regards,
Rosemary
WilbyInebriated
Quote from: Rosemary Ainslie on April 25, 2011, 12:36:59 AM
;D
Rosie
the gist of 'evolvable' hardware is simple enough. the configuration bits that program the wiring and circuitry of the fpga become the 'chromosomes' of the individuals to undergo the trial of survival of the fittest. the chip is configured, then set to do some task (like applying various settings at the gate, or something else), and its performance is measured. then the bit streams representing the best-performing configurations are mated together, mutations are added, and new individuals are tested, measured, and either discarded or mated. eventually, a configuration should emerge that’s very good at accomplishing a specific task, albeit might take thousands of generations to appear.
the beauty of it is, that you can use the fpga's as blank evolutionary 'slates' and let evolution fiddle around with the fine details. ie: you can create without any preconceptions built in. so, it’s not told anything about what is 'good' and what is 'bad' or how it achieves the behavior. evolution just plays around making changes, and if the changes produce an improvement, then fine. it doesn’t matter whether it’s changing the circuit design or using just about any weird, subtle bit of physics (note: this doesn't work on the simulation fpgas, only hardware fpgas) that might be going on. the only thing that matters to evolution is the overall behavior. this means you can explore all kinds of ways of building things that are completely beyond the scope of conventional methods. allow evolution to write all the design rules.
i hope that helps elucidate, i can be rather terse at times and expect people to 'see' what i see. it's a character flaw. ;)
