Joerg Raimund Hempel and his Ionic Magnetic Power IMP CAP Charging
Started by hartiberlin, March 03, 2011, 08:08:48 PM
e2matrix
The only thing I could find about the magnetic strips was in the patent.   Basically it says this " magnetic strips with a width of 1cm on the outer edges of which a magnetic substance had been attached in parallel to the longitudinal extension of the strips.  The polarities of the magnets running in parallel to each other were opposed."   I hate it when you have a PDF image of text so no copy and paste.  But I typed that in hoping someone can see it better than I can.
   From the patent diagram #3 and another statement in the patent it would appear there are strips on either two or possibly all 4 sides of his rectangular batteries.  I don't believe I've got any magnet strips but I may have enough small magnets to make a strip from them.  The rather big claims made in this patent and the relative simplicity of testing this make it worth checking out I believe.  It would be great if it was all this simple to get OU.
Staffman
Not sure if this pertains to this or not... The only way I know to charge a capacitor really, really fast is using DC high voltage with high current. The only issue with this method is ensuring a high sampling rate to measure the cap voltage and disconnect the voltage source when done. If you do the calculations for charging a capacitor, calculate max Q with rated voltage, then calculate the time it takes for the capacitor to reach this Q with the High Voltage. Typically the time it takes to charge is the ratio of the voltages times the ordinary charge time. Maybe the motor in the Hempel device creates this high voltage?
hartiberlin
There is no motor in the circuit.
These are just encased Li accumulators in magnets
charging up big electrolytic caps or
lead acid batteries(accumulators).
Surely you could also power a motor from it, but better first
charge up a few supercaps with it.
He said in the German patent, that he has removed the security
circuit from the cell phone Li batteries he has used.
So he uses the pure Li cells.
As there are 2 different Li cell type on the market,
Li-Ion and Li-Polymer maybe one type is working better ?
I guess also Li-Polymer is a bit safer...
Have a look here:
http://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
I Quote:
Over-discharging Lithium-ion
Li-ion should never be discharged too low, and there are several safeguards to prevent this from happening. The equipment cuts off when the battery discharges to about 3.0V/cell, stopping the current flow. If the discharge continues to about 2.70V/cell or lower, the battery’s protection circuit puts the battery into a sleep mode. This renders the pack unserviceable and a recharge with most chargers is not possible. To prevent a battery from falling asleep, apply a partial charge before a long storage period.
Battery manufacturers ship batteries with a 40 percent charge. The low charge state reduces aging-related stress while allowing some self-discharge during storage. To minimize the current flow for the protection circuit before the battery is sold, advanced Li-ion packs feature a sleep mode that disables the protection circuit until activated by a brief charge or discharge. Once engaged, the battery remains operational and the on state can no longer be switched back to the standby mode.
Do not recharge lithium-ion if a cell has stayed at or below 1.5V for more than a week. Copper shunts may have formed inside the cells that can lead to a partial or total electrical short. If recharged, the cells might become unstable, causing excessive heat or showing other anomalies. Li-ion packs that have been under stress are more sensitive to mechanical abuse, such as vibration, dropping and exposure to heat.
Charging Lithium-ion Polymer
Charging Li-ion polymer, also referred as Li-polymer, is very similar to a regular lithium-ion battery and no changes in algorithm are necessary. Most users won’t even know if their battery is Li-ion or Li-polymer. The word “polymer” has been used as promotional hype and does not reflect special attributes other than to know that the battery is built in a different way to a standard Li-ion.
Most polymer batteries are based on a hybrid architecture that is a cross between Li-ion and Li-polymer. There are many variations within the polymer family, and the true dry polymer battery for the consumer market is still years away. Also know as the “plastic battery,” this system was first announced in the early 2000 but was never able to attain the conductivity needed for most applications at ambient temperatures.
Simple Guidelines for Charging Lithium-based Batteries
    * A portable device should be turned off while charging. This allows the battery to reach the threshold voltage unhindered and reflects the correct saturation current responsible to terminate the charge. A parasitic load confuses the charger.
    * Charge at a moderate temperature. Do not charge below freezing.
    * Lithium-ion does not need to be fully charged; a partial charge is better.
    * Chargers use different methods for “ready” indication. The light signal may not always indicate a full charge.
    * Discontinue using charger and/or battery if the battery gets excessively warm.
    * Before prolonged storage, apply some charge to bring the pack to about half charge.
    * Over-discharged batteries can be “boosted” to life again. Discard pack if the voltage does not rise to a normal level within a minute while on boost.
e2matrix
Stefan, while I didn't see a motor in the video it does show a motor in all of the diagrams in the patent and states the the 'M' is a motor that he ran for 144 hours.  If I covered enough of the patent to understand it right I don't believe he states the motor is an integral part of the discovery but is a load for demonstrating it.  However knowing how patents sometimes intentionally mislead it may be something to keep in mind.
  Reading a bit further (read I actually slowed down enough to get some details) I see he is disconnecting the batteries from the caps in a timed manner to put the load onto the caps.  This actually all sounds a bit like the Tesla switch setup that Patrick Kelly describes as being used by Electrodyne except for a lack of diodes.
bolt
i found out more about this strip stuff. Its normally  isotropic magnetic material layered on one side with glue side on the other. What this means is the magnetic coating perhaps just 1mm deep has all its poles stacked vertical so that all the north poles point up for the A material and south poles point up for B material. So when they meet they stick together at any angle without alignment problems rather like velcro.
So if you buy this stuff most likely you must buy both A and B strips and either alternate the strips on the battery OR stick A on one side and B on the other. The precise layout is not discussed in great detail on the patent. I can find no material which contains horizontal N and S layered poles which i guess would be Anisotropic Magnetic.
