Thanks to ALL for your help!!
FREE ENERGY AC GENERATOR ?
Started by e2matrix, March 10, 2011, 06:02:45 PM
Goat
Quote from: teslaalset on March 11, 2011, 10:33:25 AM
The numbers from the article are based on Spice simulation with K=1 (couple factor of the transformer).
In practice this will never occur according old school theory. There are always core losses to include, so K<1, which will cause dying out of all signals.
If core losses could be compensated by an external energy source, this could work of course.
@ teslaalset
Thanks for the information, by your statement that "If core losses could be compensated by an external energy source, this could work of course." you got my curiosity peaked, I was thinking of feeding C2 as mentioned but only as ON/OFF pulses to save power and make the R a variable to tune.
My questions in the above post for the component types still is a problem for me and any help from you or others skilled in the art of electronics would be appreciated.
What kind of caps are they?
Where do you get the transformer  k3019pl_3c8?  I can't seem to find it when doing searches by part number??!
Where is L1 in relation to the capacitors?  They aren't labeled on the circuit, the only thing that is mentioned is that you would charge C2.
Sorry to repeat the questions but I'm still puzzled
Kind regards,
Paul
e2matrix
Quote from: Goat on March 11, 2011, 12:49:00 AM
@ e2matrix
Thanks for the heads up.
I found the article you posted on scribd  at http://www.scribd.com/doc/8959124/Free-Energy-AC-Generator and the same information and scope shots were there.
I did a search on the transformer model number k3019pl_3c8 and the top hits were experiments in spice... Seems as if it's a spice emulation and should work according to the program so the worst you could do is replicate it and see if it works!
There's a couple of unknowns on the diagram and the description though:
1. Doesn't indicate which side of the transformer is the primary or L1.
2. Mentions charging C2 so is that the input for L1?
3. What kind of Caps are C1 and C2? There are many different types.
There are other items but it seems like it would be easy enough to try it as long as the components can be found.
Regards,
Paul
Thanks Goat and everyone for the input.  At 33 uf they sound like they'd be electrolytic but of course that's not a given just a guess.  Either way the circuit is simple enough it wouldn't take a lot to try nearly all the combinations and even a couple different capacitor types.  I tried one setup but my caps were way higher capacitance and the transformer probably not even close.
e2matrix
Quote from: SchubertReijiMaigo on March 11, 2011, 02:55:09 AM
Hmm, a resonant trafo, look like Rotoverter/Transverter stuff I have read the whole PDF like "Combine.pdf" etc,etc. They use a so called diode pluge to extract power without reflecting back... I search another way to use the 3 Phase PrimeMover Star connection system and use it in 3 Phase trafo in solid state mode...
Another way, in your schematic, I fear when you put a load you detune the system, and you must under magnetize the trafo, (to enable resonance build up voltage/intensity) if your trafo is 480V feed it with only 120 volt (or raise the frequency)...
I have searched about RV or TV specialist to share and discut my diagram and idea, I have found a certain "Ashtweth" but it seems he is not online anymore :-[ ...
SchubertReijiMaigo,  Ashtweth is around and this is the web site he runs: http://www.panaceauniversity.org
  Lots of good info there free to download  and I am sure there will be contact info there to for you to reach him.
e2matrix
Quote from: conradelektro on March 11, 2011, 04:49:27 AM
@e2matrix:
Since some time I experiment with picking up electricity from the omnipresent RF-smog, specially in the 50 Hz range (from the 220 Volt power grid) and in the 0.1 GHz to 10 GHz range from FM-Radio-stations, mobile Phone towers and the WLAN-points.
The circuit you propose will pick up energy from the 220 Volt 50 Hz power grid (in Europe, if I remember correctly, the US has 110 Volt 45 Hz). The trick is careful tuning into resonance and a good ground connection.
In the 50 Hz range, many diodes will work, but in the GHz range one has to find really fast diodes. Eventually you need at least one diode to drive a DC load like a LED or a little pulse motor.
My experiments did not give good results, so I do not want to talk about it now. It would only confuses the issue (because I am still very confused and do not really know anything useful, just hints and speculation).
But I can tell you, specially the 220 Volt 50 Hz grid floods your building with energy that can be picked up to drive little loads with up to 10 Milli-Watt. And if you are near a WLAN or cellular phone tower, the energy is also comparatively high with a possible useful output around some Milli-Watt.
I speculate that many over unity experiments which show a little over unity pick up power from the omnipresent RF-smog. The energy in that RF-smog is higher than one would think in the first place. And many oscillating circuits pick it up specially when they have a good ground connection. Sometimes touching a circuit provides enough ground to see the effect. Touching also tunes the circuit sometimes into resonance (do not ask me why).
Greetings, Conrad
Yes I see that EMF energy around a lot and it can provide small amounts of power.  I'm looking at another circuit right now with nothing more than a big antenna, ground, 1 capacitor, neon bulb and an SCR that can charge a car battery apparently.  I just need to string the antenna as I've got the components.  It looks a lot like one of Tesla's circuits except the spark gap is replaced by the neon bulb.
e2matrix
For anyone that wants the original .pdf file with scope shots here it is: http://www.sendspace.com/file/zus03l
I believe it's also on scribd.com but I think you have to either upload there to get something or pay a fee.  The above link it totally free.
