Tri-Toroidal-Transformer
Started by nilrehob, March 20, 2011, 07:35:29 AM
nilrehob
Quote from: Magluvin on March 21, 2011, 04:26:01 AM
Hey Hob
Here is a link to peswiki of a guy that is on your same path, and his design and explanation should help you a great deal. ;]
http://pesn.com/2011/03/20/9501793_Two_Toroid_Over-Unity_Gabriel_Device_--_Part_1/
Mags
Really interesting.
/Hob
nilrehob
Quote from: penno64 on March 20, 2011, 03:24:01 PM
@Nil,
If you rewatch the video, you may notice that Thane adjusts the input voltage somewhat, to strike where PF is.
A Variac may prove useful.
Penno
Yes I have a variac,
there are quite a few variations on how to hook everything up,
i will try to cover most of them, eventually
/Hob
nilrehob
Quote from: Magluvin on March 21, 2011, 01:47:57 AM
Hey Hob
Was thinking.  the windings that are on the cores that look pre wound, I fully suspect they are all open and not being used, BUT, there may be a posibility that just he mass of copper they are composed of may interfere with what you are looking for.
If you read the first pdf, it describes how flux is manifested into the cores, and after reading it and understanding it, I believe it.  The copper of the unused windings just may be in the way, maybe slowing things down.  Like how a magnet will fall slowly on a plate of copper or aluminum on a slant. There is drag. I know that the windings are not the same as a copper plate, but there may be some interference.
Just a thought.  Would be interesting if it did make a difference. ;]
Hope you find the pdfs interesting. I was very impressed.
Mags
Yes, and the spacing between my windings and the core even if the original windings don't interfere,
i have to read about space-gaps in transformers.
/Hob
Jack Noskills
Try shorting of one output secondary, or put them in parallel/serial configration.
There are unused windings in the toroid, try shorting the ones that have primary coil around it. Idea is that it would bring the 2 cores into saturation, then maybe flux generated by the secondary coils would not affect so much to primary.
What is the idle power or your trafo ? It should be as low as possible, otherwise power is wasted. In my opinion you should get OU with this one, low idle power is important. Add turns in your primary until idle power drops atleast below 100 ma, less is better. If you can play with frequency then other option is to increase it until idle power is low enough.
