The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
wayne49s
@Casman
Ya, that's the case for me. I'll trying to validate the results with the same core material as Mav to have a baseline.
The cheapest place for magnet wire I found is at: http://www.magnet4less.com/
I'm actually planning to use #18 for the primary because it will have lower current, and #15 for the higher current, assuming we get a COP around 8.
/Wayne
casman1969
Allright, back up to speed here. Faxing my request to Jeff now.
Will be happy to split the left over 2 with you Wayne.
wayne49s
Also I'm off grid, using 24V batteries, at 400 AH. There'll be no question if  the COP is around 8, as I'll disconnect my solar panels and feed the output of Gabriel to the charge controllers going into the battery. The inverter output will feed the device input, and I plan to wire the secondary for around 60V center tap to convert it to DC for battery charging.
/Wayne
wayne49s
Quote from: casman1969 on April 07, 2011, 11:14:35 AM
Thanks for the offer, but no need...  I may use the 2nd set for some fine tuning work after, using a different core. I'm confident the Gabriel device approach has merit.
/Wayne
casman1969
Ditto on your last post. Center tap will be for my second unit but replication of the original device will be my first priority.
Glad to be in good company working on this.
