The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
importfanatik
Quote from: captainkt on April 08, 2011, 04:12:13 AM
Hi, I hardly ever post but tried Gabriel coil and followed to the letter, (the factory next door to me spins steel donuts ). I found no OU just a transformer, the toaster is probably 1kw like mine so watts in were 1350 on monitor  bulbs on secondary 350W and second monitor reads 347. I was well disapointed .
Keith
I dont see how what you just described is a case for or against OU.
How did the input watts change when you plugged in the light bulb?
Could you tell us the following?
1. Input Watts of toaster on its own
2. Input Watts of toaster connected to primary (secondary disconnected)
3. Input Watts of toaster connected to primary, secondary has light plugged in.
Thanks
casman1969
Looking forward to getting the shell and experimenting. 400' outer, 300' inner is a place to start but the variations and applications are what interest me the most. At best we can replicate as shown. At worst it may open other doors in the field of transformers. Either way, I'm pumped.
My first inner torroid will be round to, hopefully, maximize the transfer and will be fabricated from two part long curing epoxy and Iron oxide. I noticed the one on the first page of this thread was square in relation to the OD and ID. All I can find on the net are also square. If that is what works, great but I can't help but believe that round will maximize our transfer.
Mavendex
Keith
1340 watts input that's quite a bit mine is rated for 750 and I wasn't even able to pull that thru the primary it sat around 460 watts input with 400 feet of wire on, I was able to get consumption down to around 10 watts after adding more wire, maybe you saturated the outer core and stopped the magic from working, but it takes quite a bit to saturate, I have never been able to saturate the core so bad that the decoupling wouldn't work. So maybe its something in the build, remember that the outer core must completely envelop the inner core or you will have EMF interaction which will destabilize the decoupling that we are achieving.
Could you post a picture of your replication?
Mav
forest
We should find a method to check BEMF from inner coil and adjust input power/frequency whatever, because it's easier to do that then to fix magnetic shield once made.
forest
do you have any idea how to adjust this device ? This is crucial info, OU is always in method of adjustment.
