The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
Mavendex
Quote from: wayne49s on April 21, 2011, 03:34:14 PM
@all,
I got word that L&S Industries was shipping the outer donut cores out today; so for the people that ordered it, it's on its way!
They are exceptional, fits oh so perfect no gaps, and I have my first layer of tinned wire on there I will test tonight to see if we have the effects in place.
twinbeard
Hi All,
If I remember correctly, there was a question of a tuning method on this device.  Most of the tuning happens in the build, and in the selection of materials.  The only way that I could think of to tune on the fly would be to a) vary the input frequency or b) put some centertaps in your windings, like a Dunwoody crystal radio.
Cheers,
Twinbeard
e2matrix
Quote from: Mavendex on April 21, 2011, 07:36:03 PM
Cool!  Looking forward to your results.  Best of luck.
forest
Tuning is crucial I think. All free energy devices I saw on videos are quite simple but the proper method of tuning make it work in OU range. Without tuning it's just a curious shaped toy  :D
Mavendex
Quote from: forest on April 22, 2011, 04:32:36 AM
Ill agree with this statement...
First Try. Primary wound towards and to the right
120vac.05 amps primary (light bulb) - 60volts unloaded secondary
120vac2.5 amps primary (toaster)- 177volts unloaded secondary
2 layers of Primary windings .9 ohms
Acted like a normal transformer
Second Try. Primary wound away and to the left
1 layer of Primary windings .4 ohms
120vac.5 amps primary (light bulb) - 107volts unloaded secondary
120vac 5.2 amps primary (toaster) - voltage arced on the secondary and shorted to the core, intresting since my insulated windings are the very outermost layer of the secondary core and can handle 600 volts... so even if it arced and fried my windings on the inside it should not be shorting to the outercore.
Ill have to take it apart to find out what exactly happened I did hear a sizzle sizzle on the inside when it charged. most likely have to rewind the secondary with less mag wire and more insulated.
So far its quite exciting :)
Mav
