The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
sergenet
I am willing to spend a few hundred dollars to help the cause. Working together is the best thing that can be done to further the experimentation and reach a conclusion.
netpoint
So, assuming you are getting OU with this circuit, how would you go about pumping this back into your wall outlet for a grid-tie setup?
eisnad karm
@Mav
Thank you for sharing and assisting everyone. I am going to ask a dumb ass question and is not way questioning your integrity or what you have accomplished.
We had a thread last year or year before where a very decent person in England had an AC device which amplified the input to many times the out put. However when I arranged a retired physicist and electronics engineer to visit and placed a scope they were able to demonstrate he was actually using for power in than out (was deceiving the power meter and Multimeter). It had some value in cheating your power bill..but that was not the intent.
With DC in and out it is less easy to be deceived.
However, my dumb ass question is what methodology and equipment did you use to measure the power in and out.
PS is there any intention to close loop it (I understand you will need to use a buffer ,,,batteries inverters etc)
Thanks you again
Kind Regards
Mavendex
The first embodiment of this device worked as advertised but as I changed variables Im having issues with getting back to that, at a certain point of turns it reverts to a transformer at the sweet spot for every watt you put in you get 12 out, but unfortunately it requires 400 watts to get to that and thats the issue Im trying to combat at this time. the outercore is saturating allowing the secondary to interact with the primary which is bad if you can imagine, Since I can't afford to have a new shell made ive got to work with this I know a couple of tricks to cancel out the magnetic field so I can drive down consumption but thats still being experimented with.
friendenergy
Might be the spacing from Primary to Secondary. Maybe a tight glove is not a good idea. Hopefully smaller wire will work. Didn't you say you already changed the original device and it doesn't work now? Because of cutting the shell? Too bad we could have taken measurements.
Keep up the great work.
