The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
0 Members and 18 Guests are viewing this topic.
JouleSeeker
AmericanMan31:
QuoteSomehow the secondary coil in the
region outside the inner core is able to connect to an alternate source of
energy than the primary circuit.
This makes some sense to me; but would appreciate any explanation of what is ESSENTIAL in the design in order for this to occur.
  Has any one completed a replication and a test of this device?  Sure, I'm interested in the RomeroUK device too, but I still like this Gabriel-device approach very much personally.
gyulasun
Quote from: taomaster on May 22, 2011, 04:39:47 AM
BTW, there is a limit of 500KB on uploaded files, and this is currently about 370. We might have to segment this info eventually.
Hi Taomaster,
The 500kB upload limit is valid for files attached to posts here but there is an Upload/Download file transfer section too:
http://www.overunity.com/index.php?action=downloads
where the size limit is 5MB.
Go down to Category Names to choose the upload place.
Gyula
AmericanMan31
Does anybody know the inside AND outside diameter of the steel shell?.. I am trying to determine what kind of Rodin winding I can accomplish within the diameter of the shell. Thank You! ;)
AmericanMan31
Nevermind, I found the dimensions I was looking for : I.D.=60mm ;)
wayne49s
I started doing some tests, but am too busy with completing my house to complete the testing, but here's some results in case someone wants to analyse what it means. Configuration: I have a Kilowatt meter measuring the power at the wall socket, connected to an autotransformer; the output is to the device. The idle power on the autotransformer is about 10 watts.
See attached file
My secondary current measurement, I think is not accurate, so will use a low value resistor instead of the current coil probe for further tests. Plan to rectify the output. The results seem to indicate that at no load & low voltage, the secondary coil receives all the flux from the primary (even more?), but this changes as the voltage input is increased; or a secondary load is applied.
/Wayne
